Electrical Qs On Indicator Lights
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28763
Author:  Razor [ Sat Mar 03, 2007 9:52 am ]
Post subject:  Electrical Qs On Indicator Lights
Hi
I've got an alarm and the trigger light for arm/disarm is wired to the headlights, now how do I wire it to the indicator lights? I know I have to install two diodes to stop current flow so when the indicator is on it wont flash both sides.
But my indicators only work when key is on the "On" position or engine running.
Anyones got an idea on how to wire it properly?
Author:  Razor [ Sun Mar 04, 2007 12:04 pm ]
are the indicators supposed to work like this? only when key is on the IGN or ON position ?
Author:  Mick [ Sun Mar 04, 2007 3:53 pm ]
It's tough to say without seeing the wiring diagram. You need to be careful what you wire in into, you may exceed the unit's output rating for the indicator lights, particularly if it is mosfet switched.
If you wire it into the headlights, and then wire it into the indicators with diodes fitted to keep the indicators working, everytime you switch the headlights on, the current will back feed into the indicators as well, another diode added to prevent this would be large.
For simplicity, I would fit it to the headlights or indicators only.
Author:  AEG163job [ Sun Mar 04, 2007 4:55 pm ]
Yes, because the power supply is via the fuse box and the terminals for that circuit (plus others like the wipers, washers etc) is only "live" when ignition switch is on.
you could easily change this by moving the connection (green wire) to the same terminal the horns are connected to (purple wire) but I'm not sure this is a good idea because your indicator circuit would be "live" 24/7, unless you fitted another fuse to this circuit to protect against shorts etc. I would recommend you leave sleeping dogs lie :wink:
Author:  Razor [ Sun Mar 04, 2007 8:34 pm ]
Mick I was just wanting to fit it on the indicators and totally remove it from the headlights.
Author:  miniobsessed [ Mon Mar 05, 2007 4:24 am ]
Yeah you'll need to fit diodes so that when you are using your indicators they won't both flash at the same time (left and right).
To wire it all up it's quite simple:
Get your 2 diodes and join the two ends without the stripe together (from memory the diodes you want are 1N4004... but it's been a while)
Take the output from your alarm and connect that to your joined diodes (the two pins you've just joined)
Then 'tap into' your indicators - you need to find the wire that runs to your right indicators and the wire that runs to the left, strip a small section of the insulation and connect one of the diode outputs to each of these wires.
So now you should have... the output of the alarm 'splitting' through your diodes to each indicator circuit.
Make sure nothings touching and test it out, then solder it all together and insulate it adequately :wink:
You don't need to worry about power to the indicators - the alarm is supplying it :wink:
Let us know how you go :)
Author:  Mike [ Mon Mar 05, 2007 4:40 am ]
You'll only need to fit diodes if you have only one indicator output from the alarm. Many alarms have separate left/right outputs to the indicators and then no diodes are neccesary.
The indicators in the mini normaly only work with the ignition on - this is the same as most other cars (any modern car switches the indicators off when the ignition is off). To change that you'll have to switch the +12v to the flasher can from the "on on ignition" fusebox terminal to the "always on" fusebox terminal, but I cant see why you'd want to do so.
Author:  Mick [ Mon Mar 05, 2007 10:08 am ]
Shouldn't need to do anything with the 12 volt indicator supply from the fusebox as the alarm provides the 12 volts when it flashes. Just need to tap it into the left and right wire.
Author:  miniobsessed [ Mon Mar 05, 2007 3:33 pm ]
Usually the alarm systems that get hooked up to the headlights only have one output
Author:  Razor [ Mon Mar 05, 2007 6:08 pm ]
my alarm has only one output for the lights
Author:  Mick [ Mon Mar 05, 2007 6:53 pm ]
If they provide two outputs, I'll tip that the only difference is the diodes to stop one side backfeeding the other when you use the indicators. So the mod you initially suggested and was elaborated on will be fine. Just make sure you get the diode suited to the voltage and the current.
Author:  Mike [ Tue Mar 06, 2007 6:02 am ]
I was just answering his original question #2 "is it normal that the indicators only work with the ignition on?".
