It is currently Sat Jul 19, 2025 1:03 am
 Post subject: The turbonator!
PostPosted: Mon Nov 15, 2004 11:16 pm
Anybody ever heard of this before?
And would it really work?
http://www.turbonator.com/Install.html
Steve.
PostPosted: Tue Nov 16, 2004 1:10 am
without looking, im sure ive seen that b4.. its a little fan on your carb air intake, Right??
they did tests on these things a while back and they did prove to make a small saving in fuel while delivering a bit more power. the tests were on one of those current affair type programmes. they were looking for a scam and failed to find one. other than the figures being a bit hyped up..
note that was for the same type of thing but not that particular one..
in each car they tested the results were positive
PostPosted: Tue Nov 16, 2004 7:48 am
I've read tests on them too, which state that they are an utter waste of time - Danidad, I reckon the one you read was funded by one of those mobs....
read this excerpt from an autospeed article to put it into perspective
The amount of air that flows into the cylinder, compared with the cylinder volume, is called the engine's breathing - or volumetric - efficiency. In a 3 litre six cylinder engine, each cylinder has a swept volume of 500cc. If the cylinder breathes in only 400cc on the intake stroke, the engine is said to have an 80 per cent volumetric efficiency (ie 400/500 = 0.8 or 80 per cent). Volumetric efficiency will depend on lots of factors (including how well the ports flow), but let's say that the VE of the example engine is in fact 80 per cent. If this 3 litre engine is revving at 6000 rpm full throttle, this means that it inhales 7200 litres of air per minute (remember, one intake stroke per two rpm), or 120 litres per second. To put it in different units, each minute this engine consumes 254 cubic feet of air. To put that into context, a little 60mm diameter PC cooling fan flows only about 18 cubic feet per minute. So, just to flow the amount of air that this naturally aspirated, 3 litre engine needs, you'd need an array of fourteen 60mm fans working flat-out. And that's without creating any boost at all....
here's the link to the article - if it asks for you to register, close all your browsers and search for autospeed turbo supercharger, it's the first link, it should give the full article
http://www.autospeed.com/cms/A_0237/art ... larArticle
