It is currently Wed Aug 20, 2025 4:13 am
 Post subject: 1 1/2 or 1 1/4 su?
PostPosted: Mon Mar 05, 2007 7:12 am
if i changed to a 1 /14 su would i notice a change in fuel consumption?
is the power drop really significan't?
can someone please tell me the pros and cons of 1 1/2 and 1 1/4 sus ?
PostPosted: Mon Mar 05, 2007 7:31 am
A 1-1/2 SU and manifold is good for about 2-3HP gain over a 1-1/4, no downside to it if jetted right.
Keep the 1-1/2.:wink:
PostPosted: Wed Mar 07, 2007 7:12 am
yeah yourright, i'm to power hungry to do that.
i see alot of inlet manifolds with the water pipe going through the top of it? what does this do?
PostPosted: Wed Mar 07, 2007 7:32 am
Its a water heater fixture - heats the manifold up contrary to the belief it cools the manifold. Good for cold Canberra mornings - alas since I have put the DHLA on Henry winter cruises are sometimes marred because the carb ices up very badly(seems to do it right when I pass the Goulburn exits - must be the southern Highlands weather...lol)
Good to have it connected but much of a muchness
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Mar 07, 2007 10:43 am
You will find that any water heated inlet manifold will flow better than the standard cast iron one, so there you will get the extra power and may even get better economy!
Users browsing this forum: No registered users and 311 guests
