What material? https://www.ausmini.com/forums/viewtopic.php?f=2&t=29205 |
Author: | Wombat [ Wed Mar 14, 2007 1:21 pm ] |
Post subject: | What material? |
Just realised I need new gaskets under the master cylinders and their plate. MS catalogue looks like the top ones are paper and the big one under the plate looks like neoprene. I have some cork/rubber sheet about 2mm thick will that do for both? Also have some black thickish paper gasket material don't know if it's thick enough for the top ones |
Author: | Mick [ Wed Mar 14, 2007 5:03 pm ] |
I used 1.5 mm rubber, but 2mm will do fine as well. I simply then used a wad punch to punch the holes out and did the same with the heater hose entry exit holes. |
Author: | drmini in aust [ Wed Mar 14, 2007 6:12 pm ] |
I used industrial gasket material rated for steam and water, it's about 1mm thick. Anything will do really, it's just to stop rain etc dripping on yer feet... ![]() |
Author: | simon k [ Wed Mar 14, 2007 6:41 pm ] |
I cut up an old oil container.... ![]() |
