Swapping shells? https://www.ausmini.com/forums/viewtopic.php?f=2&t=29329 |
Author: | h0nk [ Sun Mar 18, 2007 12:18 pm ] |
Post subject: | Swapping shells? |
Is it possible to swap a hydro mini body, without letting the hydro bags down at all.. Basically lift the body off the subframes and drop a new one straight on? I'm just trying to think of the easiest way to do this.. Other than unbolting the subframes, exhaust electrics, master cylinders, steering column/rack, handbrake cables, what else would need to come off? Thanks.. |
Author: | drmini in aust [ Sun Mar 18, 2007 12:32 pm ] |
In theory yes but in practice I doubt it. You would need 6 pairs of hands and would probably kink the pipes. It's hard enough getting subframes out one at a time... Just let fluid out, swap it all over and I'll come pump it up. ![]() |
Author: | dove grey 64 [ Sun Mar 18, 2007 12:32 pm ] |
nope not possible, the hydro bags at the front loop thru the firewall crossmember. you have to disconect them. |
Author: | drmini in aust [ Sun Mar 18, 2007 12:33 pm ] |
1970 mini K wrote: nope not possible, the hydro bags at the front loop thru the firewall crossmember. you have to disconect them.
what he said, I forgot that one... ![]() |
Author: | DOZ [ Sun Mar 18, 2007 2:35 pm ] |
The easiest way is to take it to a mini specialist with a hydro pump and pay them to do the work ![]() I had to get the hydro pumped after removing the front subframe once, I put wooden blocks around the car and drove it about 5 kms to 'Mini' in Ctown for the pump up. It was the scariest thing I have ever done and would never do it again. Get a tilt tray, it's cheap as if you book a tow (as opposed to need from crash etc) or hire a trailer from another ausmini'er if you can. This is for the hydro re-pressurise, as for the work DIY or pay someone. Daniel |
Author: | drmini in aust [ Sun Mar 18, 2007 2:45 pm ] |
DOZ wrote: The easiest way is to take it to a mini specialist with a hydro pump and pay them to do the work
![]() I had to get the hydro pumped after removing the front subframe once, I put wooden blocks around the car and drove it about 5 kms to 'Mini' in Ctown for the pump up. It was the scariest thing I have ever done and would never do it again. Get a tilt tray, it's cheap as if you book a tow (as opposed to need from crash etc) or hire a trailer from another ausmini'er if you can. This is for the hydro re-pressurise, as for the work DIY or pay someone. Daniel Pfft... just make a hydro pump, mine cost me nix. ![]() Every time it needs a pump up, you just saved yourself around 50 bux. ![]() |
Author: | sgc [ Sun Mar 18, 2007 4:35 pm ] |
drmini in aust wrote: Pfft... just make a hydro pump, mine cost me nix.
![]() Every time it needs a pump up, you just saved yourself around 50 bux. ![]() Sounds like the beginnings of another howto ![]() ![]() Seriously, I'd be interested knowing what you've got there... |
Author: | drmini in aust [ Sun Mar 18, 2007 5:51 pm ] |
sgc wrote: drmini in aust wrote: Pfft... just make a hydro pump, mine cost me nix. ![]() Every time it needs a pump up, you just saved yourself around 50 bux. ![]() Sounds like the beginnings of another howto ![]() ![]() Seriously, I'd be interested knowing what you've got there... There are a few simple ways, I'm sure there's a thread in ausmini somewhere. For details on making a good a grease gun one, and fittings info, see Todd Miller's site- http://www.austinamericausa.com/ I made mine from a Mini clutch MC, 2x Mini front brake hoses, an upturned Fiat 124 pedal box, a bit of brake pipe, and a brass valve fitting I made by soldering a brass valve cap into a 1/8 BSP fitting. Seal is the rubber ring found inside said brass valve cap. ![]() Here's a pic- |
