alternator.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=29379
Author:  aussie [ Mon Mar 19, 2007 4:46 pm ]
Post subject:  alternator.
i need a new alternator. mine's stuffed
so. do i go new?
reconditioned rover?
recondition mine?
or will it be possible to get one of some other type of car that works better?
Author:  tinymorris1969 [ Mon Mar 19, 2007 5:40 pm ]
reco urs man
Author:  drmini in aust [ Mon Mar 19, 2007 6:27 pm ]
If the charge light blinked a bit then stayed on it's probably just the brushes are worn. $20 maybe at an auto electrician.
On most Lucas ones with the plastic back cover, you can remove and replace them without stripping the alternator apart. :wink:
Author:  tinymorris1969 [ Mon Mar 19, 2007 6:51 pm ]
mine will glow red when i first start it then after a sharp rev it goes not sure what it is yet
Author:  Mick [ Mon Mar 19, 2007 6:57 pm ]
That just means that the alternator isn't charging the battery yet, the volts at the regulator haven't reached a point where it is higher than the battery output voltage.
When you rev the engine, the volts rise and the regulator cuts the battery into the circuit, charging current is detected and the light goes out.
Author:  slinkey inc [ Mon Mar 19, 2007 7:34 pm ]
What kind have you got, if you run more electrical crap it might be an idea upgranding to a more powerful alternator. I got a Nissan Pulsar alternator (N15) it's rated at 70amps. I never draw that much but it's good to know it can keep up. Unlike my old 34amp Lucas one.
Author:  cookie720 [ Mon Mar 19, 2007 7:55 pm ]
What are the stock ones you get with clubbies? Thats what I have and I have a big audio setup coming along...12" sub, amp, 4 speakers, headunit, 6cd stacker?
Should it still be alright?
Author:  Convertible Mini [ Mon Mar 19, 2007 9:09 pm ]
Post subject:  Alternator problem ?
This will fix your problem. I have only one left. It is the Lucas style alternator same as the one used on Rover Minis. Brand new 65 AMPS it will fit straight on to your Mini using same belt and bolts. This is a must especially if you have a big sound system or driving lights. $165.00 plus postage.
Author:  cookie720 [ Mon Mar 19, 2007 9:11 pm ]
Hehe I asked if what I had is OK for what I want, If i really do need one id buy it from Minisport becase they are walking distance :wink:
