It is currently Sat Jul 19, 2025 12:37 am
 Post subject: sanding back mini
PostPosted: Thu Nov 18, 2004 12:20 am
help! :o
PostPosted: Thu Nov 18, 2004 12:37 am
tobys comment:
"does anyone kno what to do when ur sanding ur mini right back andthere is that rubber crap that u hav to get off on the inside of the back seat shelf and in the boot???"
PostPosted: Thu Nov 18, 2004 11:01 am
lol....I was removing my fuel tank and forgot to drain it. Ended up with a boot full of petrol. It dissolved that black sealant real quick.... :wink:
PostPosted: Thu Nov 18, 2004 12:33 pm
sanding sux bad!!! but you just have to keep sanding, and sanding, and sanding, till its done.. dont think there are any shorcuts LOL...
We started on the sealant (black tar) with petrol. but also found turps works as well and probably not a stinky.. gone through a ton of rags, but it comes of pretty easy..
good luck dudes
PostPosted: Thu Nov 18, 2004 12:59 pm
Yeah mate hard work will pay off in the end.
I will be in the same situation soon when I strip my new MINI K down and respray
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
 Post subject: black tar
PostPosted: Thu Nov 18, 2004 1:15 pm
thanx for that guys, the black tar so you have to replace it with anything? and aswell the foam between the boot and the body do you have to replce that?
toby,
PostPosted: Thu Nov 18, 2004 1:26 pm
Wouldnt hurt to as it is a sound deadner and the foam is to d a simuliar job.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
 Post subject: Re: black tar
PostPosted: Sat Nov 20, 2004 7:59 pm
toby,
Personally id leave the foam out....all that stuff is good for is trapping moisture and causing rust.
You can replace that black tar with more 'black tar'...such as K + H sound deadener all alternatively you could paint it
[Maverick] 1971 Mini K
PostPosted: Sat Nov 20, 2004 11:25 pm
danidad i took an angle grinder to the paint until i saw bare metal
and then after i sanded things back even
this was on the interior where small bumps n uneveness was going to be covered up by carpet
Inconspicuously Conspicuous
