It is currently Sat Aug 02, 2025 1:32 pm
PostPosted: Wed Mar 21, 2007 9:56 am
Can someone please supply me with an image of the floorpan from a Mini with remote change gearbox.
IE: Mini Deluxe, Mini K, or early Clubman.
In particluar, the floor profile where the opening for the gearstick is.
A friends Clubman has a bent floor around the gearstick and they want me to bend it back to the right profile. :lol:
 Post subject: Holes
PostPosted: Wed Mar 21, 2007 10:44 am
Some remote gearchange holes 1 is from a K the other an S
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Wed Mar 21, 2007 11:27 am
Slight hijack - mine looks just like that and I want to fill it in as I'm going back to Magic Wand. I know welding a patch in place would be best but I don't have a MIG or TIG. Would a patch secured with pop rivets be acceptable ?
PostPosted: Wed Mar 21, 2007 11:31 am
It won't be any less strong than a hole in the floor , just seal around it with a quality automotive sealant as well as rivetting it in case of any exhaust leaks .
PostPosted: Wed Mar 21, 2007 11:55 am
Andrew, thank you.
This one....
....is a lot like the car I have to repair. Cracks in the metal and bent edges.
Any idea how this happens?
AND....will a rubber boot retaining ring from a rod change be the same profile shape as the remote change?
PostPosted: Wed Mar 21, 2007 12:08 pm
The first one can be caused by "spirited driving" and heavy buggers
causes the floor to flex, and cracking around the weakest point
- the gear stick hole.
NFI on the ring :roll:
PostPosted: Wed Mar 21, 2007 12:24 pm
As far as i know the rings are the same profile.
Ph: 08-8177-1275
Skype: minisport.au
