It is currently Sat Aug 23, 2025 10:31 am
 Post subject: Bolt to front apron
PostPosted: Sat Mar 24, 2007 8:02 pm
On the clubman there is two bolt from the sub frame to the front apron.I was just about the cut the old apron to replace it with a new one when i notice this. What i want to know is if i can remove those bolt without having the engine and the sub frame falling. Are the structural or they are more for holding the front panel????
PostPosted: Sat Mar 24, 2007 8:05 pm
The subframe is bolted to the car in 4 other places. Using 8 bolts in total. Pull em out, mite b a good idea to just stick a jack under it the front of the fame just to allow the bolts to come out easier incase it drops a little.
Users browsing this forum: No registered users and 280 guests
