It is currently Sun Aug 17, 2025 2:43 pm
 Post subject: Tie Rod removal
PostPosted: Fri Mar 23, 2007 11:29 am
The threads on my tie rods are worn and I am trying to remove the old one with no success.
Any tricks other than penatrating oil and two spanners?
PostPosted: Fri Mar 23, 2007 11:34 am
I assume if you require two spanners you're at the hub end of the tie rod. No secrets, just put your back into it.
PostPosted: Fri Mar 23, 2007 12:05 pm
If you can't get them off maybe the threads aren't as worn as you think (ahh yer, rust).
Remember: if all else fails, get a BFH. :D
PostPosted: Fri Mar 23, 2007 12:39 pm
Quick zap with the welder and they came straight off.
Thanks
Users browsing this forum: Majestic-12 [Bot] and 377 guests
