Removing the Subframes https://www.ausmini.com/forums/viewtopic.php?f=2&t=2965 |
Author: | BigGig [ Sat Nov 20, 2004 12:44 pm ] |
Post subject: | Removing the Subframes |
Hey, Now I got the hydrolastics replenished, I need to ask the question - when the time comes, do I have to get them deflated by the professionals (seeing as theres 300psi in there) - before removing the subframes or can I just use a valve tool and empty them myself? I don't really fancy driving back from the shop 30 mins with no suspension. Second thing anybody got an indicator stalk plastic end for sale - I only have the metal rod with nothing on the end and it's really bugging me. Cheers all, Gig |
Author: | MiniK [ Sat Nov 20, 2004 8:08 pm ] |
U can deflate it yourself.... I posted a thread quite recently on ths one. Tip from the doc was to use the back of the valve cap to depress the valve. Just make sure you dont squirt it in your eyes. Alternatively, if you didnt have the valve caps like Moi, I used a small screwdriver to depress the valve and just washed the fluid away off the drive-way..very easy, took 5 minutes ![]() |
Author: | minstar [ Thu Nov 25, 2004 9:25 am ] |
Post subject: | Ditto |
Just did the same thing, just used my older brother's finger which is long and very point. He didn't mind losing a finger. ![]() |
Author: | lobby69 [ Thu Nov 25, 2004 9:31 am ] |
Post subject: | . |
or do what i did!, use a screw driver, but do catch the liquid, the stuff stinks!, i just put a plastic bag over the valve with the srecdriver insinde, u get the point!, blake ![]() |
Author: | Wombat [ Thu Nov 25, 2004 10:36 am ] |
MK1 green bit? - I have a spare new one or you can buy from MiniSpares http://www.minispares.com/Product.aspx?pid=37011 |
Author: | 1380 yellow devil [ Thu Nov 25, 2004 2:18 pm ] |
I just undone the valve with a vlave remover and caught all the fluid and no problems at all |
Author: | MiniK [ Sat Nov 27, 2004 5:15 pm ] |
Is the front subframe(wet) easy to unbolt? Ive gotta take it out so i can mount my frame on my rotisserie ![]() |
Author: | drmini in aust [ Sat Nov 27, 2004 6:18 pm ] |
MiniK wrote: Is the front subframe(wet) easy to unbolt? Ive gotta take it out so i can mount my frame on my rotisserie
![]() Yes once you remove hydro hoses and shocks.. 4 bolts in the towers, 4 in the floor, 2 at the front. Watch the front valance hasn't been bent under the subby- whack it forward with BFH if so. If it's still stuck, pry from each side, on top of the towers. ![]() If you are converting it to dry, please don't chuck the hydro bits- some people on here would buy them. ![]() |
Author: | MiniK [ Sat Nov 27, 2004 6:28 pm ] |
I probably will be converting to dry, but ill be keeping my wet bits (Dont read that rudely ![]() I dont believe in wastage ![]() |
