It is currently Thu Aug 14, 2025 1:24 am
 Post subject: Coil Question
PostPosted: Wed Mar 28, 2007 10:04 am
Excuse my electrical ignorance, but if my coil was stuffed could it possibly be the cause for the reason my engine struggles to kick over. Have followed the whole process from go to whoa, am getting fuel, everything connected, but have to give it a bit of extra each time from my jump starter. Is giving me the irrates. :evil: Bloody lucifer
(\_/)
(O.o) <CoPy> <) MaY oBtAiN wOrLd DoMiNaTiOn.
PostPosted: Wed Mar 28, 2007 1:42 pm
A fair bet. Why not swap it with another & see if there's any improvement.
A good methodolgy(?) with Mini electrics is process of elimination, by simply substituting parts.
It helps if you know the replacements parts are kosher :wink:
PostPosted: Wed Mar 28, 2007 1:54 pm
I had a stuffed coil once - the thing did deliver a spark but the engine would not fire. Probably cause it was dark on a wet night the spark looked bigger and healthier than it was - finally put in a new coil - VARROOM :wink:
David L
PostPosted: Wed Mar 28, 2007 2:17 pm
I Had an issue with the ignition switch once, just dropped out so the coil wasn't getting any volts when the key was turned to 'start'. replaced it and "varoom"
:wink: :wink:
PostPosted: Wed Mar 28, 2007 4:05 pm
guess it wont hurt to replace anyways will have a spare if it is not the problem
(\_/)
PostPosted: Wed Mar 28, 2007 5:18 pm
If the coil is getting hot (even with engine not running), it's stuffed.
Standard Mini dizzy? Get yourself a GT40 or even better (what I have), aGT40T Don't get the GT40R or GT40RT, they are resistor ones, not suited to Mini dizzy's.
 Post subject: Re: Coil Question
PostPosted: Wed Mar 28, 2007 10:17 pm
If it struggles to kick over, check it is not over-advanced. :wink:
Users browsing this forum: No registered users and 280 guests
