another guy on crack? https://www.ausmini.com/forums/viewtopic.php?f=2&t=29730 |
Page 1 of 2 |
Author: | dove grey 64 [ Tue Mar 27, 2007 12:54 pm ] |
Post subject: | another guy on crack? |
check this out http://cgi.ebay.com.au/1963-MORRIS-MINI ... dZViewItem personaly i dont think its a cooper. Quote: UNFORTUNATLY IT DOES NOT HAVE THE ORIGINAL ID TAGS OR ANY BADGES BUT I HAVE SPOKEN TO A FEW MINI ENTHUSIESTS WHO HAVE POINTED OUT SOME OF THE FEATURES THAT ONLY THE COOPERS HAVE:
AIR SCOOP IN FRONT GRILL, ELECTRIC FUEL PUMP MOUNTED ON THE SUBFRAME, 2 STEEL BRACKETS FOR THE HEATER UNDER THE IGNITION. air scoop? electric fuel pump on subframe? steel brackets for heater? my 62 850 has all that stuff apart from a "air scoop". also what about the diag front grille brace. maybe coopers didnt have them. crack head or not. sounds like an ok guy, maybe he got ripped off |
Author: | Harley [ Tue Mar 27, 2007 1:01 pm ] |
1.5k for a car without an ID plate? Pass. ![]() |
Author: | sports850 [ Tue Mar 27, 2007 1:04 pm ] |
Post subject: | Re: another guy on crack? |
1970 mini K wrote: also what about the diag front grille brace. maybe coopers didnt have them.
No diagonal brace on the 998/997 cooper , anyone going to ask him for more details etc ? |
Author: | willy [ Tue Mar 27, 2007 1:05 pm ] |
I just told him that the Cooper should have 7" disc brakes. As it should. |
Author: | dove grey 64 [ Tue Mar 27, 2007 1:32 pm ] |
i also thought all the 997/970/998/1071/1275 coopers had boot boards. did 63 coopers have deluxe style wind up doors? also about the air scoop, its a fresh air duct that goes to the firewall isnt it? not for the carbs or anything |
Author: | Anto [ Tue Mar 27, 2007 2:05 pm ] |
The air scoop can be seen in the second picture, it isn't Cooper specific a lot of 850s had them too. Sounds to me like an 850 with a factory fitted fresh air heater. Certainly doesn't have Cooper doors! Either way, assuming it is registerable without the build plate, doesn't seem like to bad money for what you get. |
Author: | Morris 1100 [ Tue Mar 27, 2007 7:19 pm ] |
1970 mini K wrote: did 63 coopers have deluxe style wind up doors? No. They didn't start making the Deluxe wind-up doors till 1965.
Author: | miniobsessed [ Tue Mar 27, 2007 7:40 pm ] |
Has anyone thought to ask for the body number? ![]() |
Author: | sports850 [ Tue Mar 27, 2007 7:55 pm ] |
I have but he hasn't got back to me yet . |
Author: | HPDesign [ Tue Mar 27, 2007 7:59 pm ] |
since when does an unfinshed project constitute one that hasn't even started |
Author: | Anto [ Tue Mar 27, 2007 8:53 pm ] |
miniobsessed wrote: Has anyone thought to ask for the body number?
![]() What's that going to achieve if it doesn't have a build plate? |
Author: | Morris 1100 [ Tue Mar 27, 2007 9:08 pm ] |
Anto wrote: miniobsessed wrote: Has anyone thought to ask for the body number? ![]() What's that going to achieve if it doesn't have a build plate? The body number is a clue to working out what the car is. If it does not have any numbers under the bonnet you will have a hard time getting rego. ![]() |
Author: | Anto [ Tue Mar 27, 2007 9:11 pm ] |
Yes but the number stamped on the firewall won't tell you if it is a Cooper or not. Not on an early model car at least. |
Author: | Mick [ Tue Mar 27, 2007 9:19 pm ] |
What about the one on the radiator shroud? Should have YKA2S? ???? there shouldn't it? |
Author: | Anto [ Tue Mar 27, 2007 9:24 pm ] |
Not on early models. Well at least mine doesn't. Later models like Mini Ks has YG2S4 or whatever on the shroud. They also omitted the 'K' / 'M' on late models, which makes things more difficult. |
