Oh bum https://www.ausmini.com/forums/viewtopic.php?f=2&t=2983 |
Page 1 of 2 |
Author: | poeee [ Sun Nov 21, 2004 3:51 pm ] |
Post subject: | Oh bum |
A picture says 1000 words (or just "the thinga broke") ![]() Edit/ oh... is this the same thing? http://cgi.ebay.com.au/ws/eBayISAPI.dll ... RK:MEWA:IT |
Author: | drmini in aust [ Sun Nov 21, 2004 3:54 pm ] |
Bloody common Clubbie part- must be thousands lying about. I got some in Sydney but someone must be closer to you. ![]() ![]() |
Author: | poeee [ Sun Nov 21, 2004 3:56 pm ] |
drmini in aust wrote: Bloody common Clubbie part- must be thousands lying about. I got some in Sydney but someone must be closer to you.
![]() ![]() Well before I take it somewhere to get welded, I better decide which is a better option before the ebay auction ends (might not have one up again for weeks, who knows). So weld or new? |
Author: | drmini in aust [ Sun Nov 21, 2004 5:32 pm ] |
poeee wrote: drmini in aust wrote: Bloody common Clubbie part- must be thousands lying about. I got some in Sydney but someone must be closer to you. ![]() ![]() Well before I take it somewhere to get welded, I better decide which is a better option before the ebay auction ends (might not have one up again for weeks, who knows). So weld or new? I'd weld it. It will be stiffer after welding- less likely to flex and break. |
Author: | WhoDat [ Sun Nov 21, 2004 5:43 pm ] |
That guy has one of those steadies up every 4 days or so - about a rare as a grass on the MCG ![]() Cheers Dat |
Author: | poeee [ Sun Nov 21, 2004 5:48 pm ] |
No grass on it at the moment!!! |
Author: | willy [ Sun Nov 21, 2004 6:15 pm ] |
OMG! Thats gonna happen to me soon - isnt it Dr Mini. Remember i asked about what that knock sound is when you decelerate then reapply the gas. ![]() |
Author: | drmini in aust [ Sun Nov 21, 2004 7:06 pm ] |
Hell yes! Don't set the car afire though.. fuel line is not far away... ![]() |
Author: | willy [ Sun Nov 21, 2004 7:23 pm ] |
Heh... should i take it out to do it? That would probably be logical (being blonde myself and all ![]() |
Author: | drmini in aust [ Sun Nov 21, 2004 7:30 pm ] |
If the bracket is cracked, yes take it out. If the body crossmember is cracked (common) you have to weld that in there. I would take the carb and outlet line off the fuel pump, put a short bit of hose on the pump with a bolt in it to seal. And put some sheet metal below where you are welding, above pump- so you don't drop sparks in there. |
Author: | Mike [ Mon Nov 22, 2004 6:20 am ] |
might also be worth your while to put a 3-5mm sandwich plate on the other side of the crosmember to spread the load from the engine steady better and strenghten the panel coz the metal there is very thin and prone to cracking. |
Author: | drmini in aust [ Mon Nov 22, 2004 6:41 am ] |
Better yet do as Bnicho suggests- fit another pedal box in there.. it's got studs in it already. ![]() |
Author: | J_A_M [ Mon Nov 22, 2004 7:18 am ] |
hmmmmm....the thread title is OH BUM....and it's written by POEEE......I am seeing a common pattern emerge with bums and the chief..... ![]() ![]() |
Author: | poeee [ Mon Nov 22, 2004 11:20 am ] |
Author: | bnicho [ Mon Nov 22, 2004 11:35 am ] |
I must have at least two of these lying around. Every clubby from 74 on has one. Poeee, try Macwreck. |
