It is currently Sun Aug 03, 2025 12:41 am
PostPosted: Tue Mar 27, 2007 11:03 pm
Hi all,
My air filters are in need of replacing very soon and was wanting to go with a good quality long lasting filter or more to the point a K&N filters. they are to go on twin 1 1/2 SU's. I know of at least one person on here that has them on their car but i cant remember who?
Does anyone know the part number for them or do they have to be custom made?
>Rude<
1992 Toyota Starlet GT EP82
PostPosted: Tue Mar 27, 2007 11:07 pm
This space for rent
Your avatar shows your current filters briefly.. I don't remember what they're called but I had those on my last Mini (on twin 1-1/4's). What's so wrong with them that you'd want to change to K&N's?
PostPosted: Tue Mar 27, 2007 11:10 pm
you could use ramflow filters???
the k and n ones are quite expensive, and places like minisport have them in stock.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Mar 27, 2007 11:14 pm
they may look alright in that little avatar picture, but they are paper like and the rubber surrounds had to be ground down with a grinder in order for them to fit (they are dodgey repco ones) plus that picture is over a year old now, they are looking very dark and dirty now.
something like this i think
Part number: 56-9320
can anyone clarify this?[/img]
PostPosted: Tue Mar 27, 2007 11:37 pm
This is what i was running before the blower, sorry don't have 2 as i will probably flog this one off soon..
I got this one from autobarn for less than $100, but i did get a discount.
I wouldn't run ramflo's, personal opinion, but i don't believe they match the quality of the k&n product... Part no. is 56-9320. That is for 1 1/2 inch...
Carl
PostPosted: Tue Mar 27, 2007 11:42 pm
thanks for clearing that up sox61, i know a few people in the business so hopefully it won't be too expensive :wink:
>Rude<
PostPosted: Tue Mar 27, 2007 11:48 pm
No probs, well worth the money IMO.
Carl
PostPosted: Wed Mar 28, 2007 7:58 am
K&N are worth the extra dollars. They will bolt straight on and look like this..
PostPosted: Wed Mar 28, 2007 10:11 am
Ive got Finer Filters that fit into my Ramflo filter housings. The stock Ramflo filters are crap.
PostPosted: Wed Mar 28, 2007 9:37 pm
Give Ash some flowers Nick .
I have read somewhere that those tapered K&N filters don't flow that well. Depends what you want from your engine.
I have K&N's and IMO they are worth it. You won't regret it.
PostPosted: Wed Mar 28, 2007 10:25 pm
Here are the Finer Filters that i fitted to my Ramflo filter housings.
PostPosted: Wed Mar 28, 2007 10:38 pm
very shinnyful su's u got there hanra, then again your car is pristine everywhere!!! 8) personally i dont like the ramflow ones IMO, with K&N at least i kno i am getting quality, a bit of performance and durability/reuseability.
what seems to be the problem with the tapered filters 1018cc?? its for a daily driver too btw....
PostPosted: Thu Mar 29, 2007 6:54 pm
I think some one posted up something on here that KC did in the UK and he showed on a dyno that they don't flow as well - the standard airbox on the car with a replacement good quality filter made more power than the tapered K&N. I don't think that there was much in it but it showed on the dyno.
Depends what you want - if you just want it to look good then go for it but if you are after a bit more power as well then I would probably go the cylindrical pancake style ones or ramflows with different internals like Hanra's.
PostPosted: Thu Mar 29, 2007 7:10 pm
I think ramtubes probably flow the best, but may not look as good. I mean chrome ram tube (aka trumpets) look great, but but don't look as cool with the redline filters on them. I believe ramtube + redline filter would be the best performance and filtration.
I have it on the HIF44 which faces forward so space is not really an issue, with the baulkhead it may well be.
I used to run ram-flos on my twins and the fine, they looked nice too.
PostPosted: Thu Mar 29, 2007 9:07 pm
I got these, dunno if they do anything.... But at least ive got the wank factor
