alternator https://www.ausmini.com/forums/viewtopic.php?f=2&t=29852 |
Author: | Blokeinamoke [ Fri Mar 30, 2007 12:16 pm ] |
Post subject: | alternator |
I rebuilt my alternator with a new diode pack,contacts,voltage regulator etc It bench tested OK Now that it is installed I am getting 13.95v @idle.This seems a little high What should I be expecting? |
Author: | Mike_Byron [ Fri Mar 30, 2007 12:26 pm ] |
Mine gives roughly the same voltage at the same time. Always has over the 12 years I have owned it and the battery and the alternator are still the same. |
Author: | Harley [ Fri Mar 30, 2007 12:34 pm ] |
14v seems normal. It's the current that changes with revs. ![]() |
Author: | Wombat [ Fri Mar 30, 2007 1:07 pm ] |
Thats fine - max battery voltage fully charged is 13.8 so you need to be over that to get the battery up to that. Not too much over or you boil the battery - besides you will have line loses anyway. |
Author: | drmini in aust [ Fri Mar 30, 2007 3:00 pm ] |
Unlike a generator, an alternator actually charges pretty well at idle. Sounds normal to me. If you rev it, it probably won't go past 14.3V anyway, which is normal. ![]() |
Author: | Blokeinamoke [ Fri Mar 30, 2007 3:11 pm ] |
Great. I was trying to establishthe baseline voltage - Thanks |
