It is currently Sun Jul 27, 2025 8:31 pm
 Post subject: alternator
PostPosted: Fri Mar 30, 2007 12:16 pm
I rebuilt my alternator with a new diode pack,contacts,voltage regulator etc
It bench tested OK
Now that it is installed I am getting 13.95v @idle.This seems a little high
What should I be expecting?
PostPosted: Fri Mar 30, 2007 12:26 pm
Mine gives roughly the same voltage at the same time. Always has over the 12 years I have owned it and the battery and the alternator are still the same.
PostPosted: Fri Mar 30, 2007 12:34 pm
14v seems normal. It's the current that changes with revs.
:D
PostPosted: Fri Mar 30, 2007 1:07 pm
Thats fine - max battery voltage fully charged is 13.8 so you need to be over that to get the battery up to that. Not too much over or you boil the battery - besides you will have line loses anyway.
David L
PostPosted: Fri Mar 30, 2007 3:00 pm
Unlike a generator, an alternator actually charges pretty well at idle.
Sounds normal to me. If you rev it, it probably won't go past 14.3V anyway, which is normal. :wink:
PostPosted: Fri Mar 30, 2007 3:11 pm
Great. I was trying to establishthe baseline voltage - Thanks
