It is currently Tue Jul 22, 2025 7:08 pm
 Post subject: Fuel pump question
PostPosted: Sat Mar 31, 2007 10:23 pm
Hi all.
Just sourced a near new mechanical pump to replace a broken, later type, non repairable pump on my 77 clubby.
Looks like a Goss pump, but slightly different top. It has a plastic rubbing block that sits on the cam. The only markings are the letters EH stamped into the top.
My original pump had a plastic insulator/spacer about half inch thick & my gasket set has one in it which is about 3/8 inch thick with gaskets already glued in place.
Question is, any way of knowing which spacer to use if at all? The guy I got it from couldn't help.
Thanks. Scotty.
 Post subject: Gosh!!
PostPosted: Sat Mar 31, 2007 11:04 pm
No eye deer :!: ,,,hopefully someone will have first hand experience :!:
PostPosted: Sat Mar 31, 2007 11:13 pm
hope someone can help mate...
Users browsing this forum: fuzzy-hair-man, timmy201 and 76 guests
