It is currently Sat Jul 26, 2025 6:32 am
PostPosted: Sun Apr 01, 2007 12:05 pm
Now please help me out. I have a Moke, which sometimes after sitting a days with it's cut off switch not turned off :oops: needs to be jumpstarted.
So as you know Mokes batteries are tucked away in that little compartment that you need a big screwdriver to open. I know Dad sometimes jump starts it off somewhere in the engine bay, could someone photoshop my pictures with little circles, ( I've seen done on here before) where the leads need to be attached :D
Thanks heaps for this, I am starting to sound like a dumb chick who knows nothing about my own cars :shock:
1979 Leyland Moke (which is for sale)
PostPosted: Sun Apr 01, 2007 12:15 pm
Put the POS red jumper lead where i put the red dot.
The NEG black lead needs to go to a good earthing point. Usually there is an earth strap from the clutch housing to the body. Looking at the engine like this, its on the LHS towards the front of the car sort of at the bottom of the clutch housing...
PostPosted: Sun Apr 01, 2007 12:59 pm
Just put the negative on something with not a lot of paint on it like a clean bolt or the hot water take-off at the end of the head near the solenoid. The cleaner the connetcion point and the more of the clamp touching it, the quicker/stronger/better the jump start.
Connect negative last, that way there's less chance of shorting the positive out on the frame when you connect it up. Same with removing it, take the negative off first.
PostPosted: Sun Apr 01, 2007 1:12 pm
Thanks very much for the help. That's exactly what I wanted. You ausmini people are champs :D :D :D
It all worked so thankyou so much.
Now after a clean I can get this Moke out on the road on this sunny Sunday. :D :D :D
PostPosted: Sun Apr 01, 2007 2:32 pm
I usually connect the -ve to one of the head studs
