Clicking noise... Problem Found... Temporary Fix https://www.ausmini.com/forums/viewtopic.php?f=2&t=29971 |
Author: | Marvin [ Mon Apr 02, 2007 12:36 pm ] |
Post subject: | Clicking noise... Problem Found... Temporary Fix |
When I'm accelerating I can hear a clicking noise from the engine bay... well that's what it sounds like from inside the car. When I'm sitting on the speed limit 50/60/70 whatever it is at the time I can't hear it. EDIT: I can't hear it when I just sit there and rev it either so it's only under load that I can hear the noise. |
Author: | aaron [ Mon Apr 02, 2007 2:23 pm ] |
1st guess is CV Joint is on the way out. Cheers Aaron |
Author: | Mini Mad [ Mon Apr 02, 2007 2:37 pm ] |
Yea - does it get worse when on full lock - say doing a u-turn? |
Author: | AEG163job [ Mon Apr 02, 2007 3:06 pm ] |
At least its clicking & not ticking............ ![]() Not a timing chain sorta noise is it? |
Author: | sports850 [ Mon Apr 02, 2007 4:56 pm ] |
As a paranoia check , how's your oil level ? |
Author: | Marvin [ Mon Apr 02, 2007 5:06 pm ] |
MM - No extra noise on full lock S850 - Oil level is just over max If listening closely I can hear it a little when revving the car. Could it be a hole in the exhaust? |
Author: | 9YaTaH [ Mon Apr 02, 2007 5:46 pm ] |
Post subject: | Gasket??? |
Marvin wrote: MM - No extra noise on full lock
S850 - Oil level is just over max If listening closely I can hear it a little when revving the car. Could it be a hole in the exhaust? Yes...could be a manifold gasket....try dribbling a tiny bit of oil along the top edge of the gasket to see if it blows bubbles.... [edit: don't dribble the oil from your mouth ![]() |
Author: | hbr [ Mon Apr 02, 2007 7:46 pm ] |
big end bearing? |
Author: | 9YaTaH [ Mon Apr 02, 2007 10:13 pm ] |
Post subject: | Thinkin... |
Fan touching shroud ![]() ![]() or Alternator bearing ![]() or Its an A Series....turn the radio up ![]() ![]() |
Author: | Gadgets mini [ Mon Apr 02, 2007 10:15 pm ] |
football card in the spokes ![]() |
Author: | Marvin [ Mon Apr 02, 2007 10:16 pm ] |
Post subject: | Re: Thinkin... |
9YaTaH wrote: Its an A Series....turn the radio up
![]() ![]() It's loud enough already with the weber and exhaust without the radio on... ask adeee ![]() |
Author: | Marvin [ Tue Apr 03, 2007 8:17 pm ] |
About half way to work today I slowed down for a set of lights and my car started to sound like a VW Beetle ![]() There was no loss of power so I just kept driving to work. Go to work, flipped the front and spotted 2 holes in my extractors ![]() There's supposed to be a bit of metal connecting the 2 pipes but that seems to have disappeared. One of the holes... ![]() both holes... bit hard to see ![]() the connection from the y-piece to the motor... ![]() So now I'm looking for a replacement. |
Author: | willy [ Tue Apr 03, 2007 8:19 pm ] |
Bit of weld, she'll be right. Its a sign that the metal is thin and probably won't last long. |
Author: | Marvin [ Sat Apr 07, 2007 8:30 pm ] |
Bought some Loctite exhaust repair and put it on today. Cut up one of last nights cans of 'Beam & coke' into 2 20cm squares (which it says to do), covered the holes then wrapped the repair ribbon/tape around the exhaust. You are supposed to ide the car for 20-30 minutes so that the heat makes the ribbon harden. This is the result... it's only temporary as I planned to get new extractors anyway. ![]() ![]() |
