It is currently Tue Aug 05, 2025 11:50 pm
 Post subject: Octane boosters?
PostPosted: Tue Apr 03, 2007 12:07 pm
I want to have Al's babies
Apparently there are products on the market that boost the RON of your petrol (for if you are somewhere where you can't access 95 or above).
Anyone know of a good one / use one / whatever?
PostPosted: Tue Apr 03, 2007 1:13 pm
Slow-Po
The search is your friend :wink:
http://www.ausmini.com/forums/viewtopic ... ne+booster
contains this gem of a quote :)
if you want high octane fuel, buy it, don't tip snake oil in from a bottle.... :wink:
PostPosted: Tue Apr 03, 2007 1:14 pm
Give Link a call.
Can't remember the name but they sell an additive that works - not cheap though.
PostPosted: Tue Apr 03, 2007 1:38 pm
Thanx, Ben. I know it is, but never seem to find what i want. This case seems to have been an exception... :oops:
PostPosted: Tue Apr 03, 2007 1:53 pm
VicMini13 wrote:
Give Link a call.
That stuff is has LEAD in it, too! 8)
PostPosted: Tue Apr 03, 2007 5:08 pm
if you want leaded high octane fuel try and get a hold of some avgas. Otherwise shell has 100 octane on tap @ most servo's
Don't buy the boosters, they are a waste of time effort and money. and most have been proven to actually lower high octane fuels octane when added so they often contain little of the extra power
and a few conversions:
13B Extend in a 1600
PostPosted: Tue Apr 03, 2007 6:04 pm
The 100 octane at shell has ethanol in it, so be wary of that. BP Ultimate, i've heard, is actually made to 100 octane, to be carefull if it looses octane if it ever gets tested. All other 98 octane stuff is made to 98 octane.
PostPosted: Tue Apr 03, 2007 6:34 pm
The first question to ask is, what makes you think that you need higher octane fuel?
If you really need higher octane fuel the best thing is to buy a higher grade at a servo.
There are simple ways to raise the octane level without buying snake oil, toluene is a quick fix if used correctly, the oil companies use it themselves for that reason.
PostPosted: Tue Apr 03, 2007 7:09 pm
That's not my question, Morris. :)
My question is, because the Mini requires a minimum of 95, if i go for a long drive intra-state and CAN'T GET anything higher than 91 at any stations, then what should i carry in the event of that situation?
I'm not intending this for daily use or anything. If i'm in melb, i buy the right octane.
PostPosted: Tue Apr 03, 2007 7:19 pm
95 is available pretty well everywhere now.
When we did Tassie last year, we took Barney over, because unlike mine he runs fine on 95. No 98 over there, matey! :lol:
PostPosted: Tue Apr 03, 2007 7:23 pm
There are more stations selling 98 octane on the way to Adelaide than you need to stop at in a Mini.
I would imagine going to Sydney would be the same... there are definatly enough Macca's along that road!
PostPosted: Tue Apr 03, 2007 7:24 pm
OK I will change the question to, what makes you think you need 95 octane? What happens if you run 91?
PostPosted: Tue Apr 03, 2007 7:27 pm
Um, the sticker under the bonnet that says RON95. :lol: Remember that mine's an import. It pings with anything less. :)
PostPosted: Tue Apr 03, 2007 7:41 pm
Looks like you are stuck with 95 then. :wink: (Or carry a can of toluene 8) )
Is yours injected? If it has a cat you run a risk with any of the octane in a can boosters.
With normal cars you can knock off a couple of degrees of advance to cure the pinging. (this was why the D25 dizzy has the thumb wheel on it)
PostPosted: Tue Apr 03, 2007 8:01 pm
Try Octane Supreme 130. Proper lead based fuel additive. Will boost octane rating by at least 5 depending how much you add (5 octane boost all that is allowed by Aus legislation). Not for cars with cats of course.
