It is currently Tue Aug 19, 2025 6:12 am
PostPosted: Wed Apr 04, 2007 11:48 am
Hi guys,
Does anybody know a stockist of 7.5" disc pad anti-rattle springs for a Cooper S? I haven't got them on my car and I sometimes hear them 'tink,tink,tinking" as I drive. A tap on the brake pedal seems to stop it so I think springs are what I need.
Best regards
Al
PostPosted: Wed Apr 04, 2007 12:24 pm
You can make them out of milo tin by finding an old second hand one and using it as a template. AFAIK they are no longer available....
Alternative I think is to put some silicon based brake compound on the back of the pad where it touches the piston like in some modern cars.
PostPosted: Wed Apr 04, 2007 12:35 pm
Hi Lillee,
I don't have a pattern unfortunately! It is possible that springs from something else will do the job, someone might know what??
The compound on the pad is usually to stop squeal and I doubt it will help the problem I have.
Al
PostPosted: Wed Apr 04, 2007 2:01 pm
The compound (Although I have limited knowledge cept that I used some on my commodore few years back) makes the pad stick to the piston, therefor elimating movement and rattle. But like I said, don't quote me on that one! :oops:
PostPosted: Wed Apr 04, 2007 2:08 pm
Hi Lillee,
Hmmm, that might work, I never thought of it working that way. Have you any idea who's product it was?
Al
PostPosted: Wed Apr 04, 2007 7:36 pm
Unlike the 8.4" discs, Cooper S 7.5s never had anti-rattle springs.
The pins just go straight thru the pads. 998 Cooper was the same setup.
They did have anti-squeal shims, but as said these are rocking horse now.
PostPosted: Thu Apr 05, 2007 8:48 am
I believe this is caused by disc "run-out". The factory manual specifies the limit (can't remember it off the top of my head). Can be checked with a dial guage and reduced/eliminated sometimes by repositioning the disc/flange assembly on the CV spline, or replacing the flange if worn inside. Repositioning the disc to eliminate run out is a frustrating, time consuming exercise (a C o a Job), so it may be easier to just turn the stereo up :wink:
PostPosted: Thu Apr 05, 2007 9:26 am
Hi Pete,
The discs (and pads) are new and running within a couple of thou. The frustrating thing is they never did it with the old discs which weren't true! The problem is minor, I agree but I felt that the original shims may well have had a dual function, holding the pads steady as well as reducing squeal. I can probably make something to do the job. Thanks for your thoughts.
Al
PostPosted: Thu Apr 05, 2007 9:35 am
Hi Al,
It's a common product, I would ask your local Repco or Autopro. I know that most garages will use this type of product when doing brake pads...
PostPosted: Thu Apr 05, 2007 9:47 am
Yep. From memory they're made from a thin springy type material. Brake specialists might also be worth a shot. :idea:
PostPosted: Thu Apr 05, 2007 9:50 am
ausmini mod
ausmini mod
Guys, It looks like your talkinig about 2 seperate things (as Doc mentioned)
There are anti-squeel shims (I have some, old, can be used as a template if you want (soon as I find them)
The other part is the Spring that sits across the two pads... retaining spring.
Ive never seen one, dont think they came on 7.5" disks (cooper) and are generally not needed... thats whats causing the tink tink I believe.
Peter.
PostPosted: Thu Apr 05, 2007 9:56 am
Hi Peter,
I acknowledged the purpose of the shims a few posts ago and I said I thought they may help hold the pads steady. I've not seen one, so I don't know but I am aware that anti-rattle springs usually fit on top of the pads. Thanks for pointing out the possible confusion mate.
Al
PostPosted: Thu Apr 05, 2007 10:36 am
Peter.
you surely do need them. A previous car I had had the springs and I also followed the opinion that they were no necessary, that was until the pad material seperated from the backing plate. The cause was the pad rattling around had weakened the back of the friction material.
You really dont want that to happen at speed.
You can get larger ones and then cut them down and then curl the ends so they all fit. Thats what I do to great effect and never had a problem.
PostPosted: Thu Apr 05, 2007 11:47 am
I had this issue with my lancer, the clip got damaged and I am running without one. It makes a light rattle sound when going over bumps, and very rarely when I pull up, I get a low vibration noise like a truck.
Asked a couple of shops and no-one can get them, some pads may come with them - put can't find any.... And this is for a lancer, on the rear so I don't care too much - good luck on the mini!
PostPosted: Thu Apr 05, 2007 12:19 pm
FYI I don't run anything on my car, but I have relatively new pads (less space for them to rattle)...
Users browsing this forum: No registered users and 210 guests
