It is currently Sat Jul 19, 2025 12:26 am
what do you think of holdens new dark pirple?
Poll ended at Thu Dec 02, 2004 9:17 pm
yes, i like it 67%  67%  [ 4 ]
i donno 33%  33%  [ 2 ]
Total votes : 6
 Post subject: help its a big job
PostPosted: Mon Nov 22, 2004 9:17 pm
i hav my mini siting in the shed, compleately striped exept for the rear sub frame and axle and it is on its way to being compleatels sanded jusat all the hard bits to go.
there is two rust spots in the corners of the cab, ive got a spare floor to cut out one bit and already fixed the other. there is all that black rubber crap i hav no idea what to do with it its just annoying!!!! it clogs your sandpaper!!! and the instulation what the?
i am painting it the new dark pirple that holden have released it looks pritty sweet so i have the paint all i need to kno is how to under coat it and get it ready to paint!
if anyone has got any advice for me it would be great
 Post subject: Re: help its a big job
PostPosted: Mon Nov 22, 2004 9:27 pm
My advice is....
pritty = pretty
pirple = purple
:lol:
but seriously, use a wire wheel on a drill to rip that black sealant off...and it's great for getting off the crud left after removing the insulation material. PM gafmo for advice on that, he is an ace with them
some painting tips can be found here-----> HERE
PostPosted: Mon Nov 22, 2004 9:38 pm
wheel on a dreel?
thatd clog up the hairs big time and make it useless
attack with a chisel
and a bottle of good petrol
i'd advise a desktop fan too unless youd like to get wiffin'
Inconspicuously Conspicuous
PostPosted: Mon Nov 22, 2004 9:46 pm
thanks for that buddy that is heaps of help do you really have to apply that many under coats and sand it back continusly? it sounds like alot of work :(
PostPosted: Mon Nov 22, 2004 10:09 pm
Drill.... swill.. :x
get 4" angle grinder, fit 4" diameter twistknot wire wheel, put on facemask. Rips her off quick smart, 10,000+ rpm- and lasts forever compared to those little hairy drill brushes.. :P
PostPosted: Tue Nov 23, 2004 6:53 am
:lol:
I only used ONE of those on JAM.....it lasted forever....but JAM was in OK condition before I started. The paint was VERY thin, which helped a lot :wink:
PostPosted: Tue Nov 23, 2004 12:59 pm
Try using Thinners or turps instead of the petrol and it is cheaper.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Nov 23, 2004 2:16 pm
Make sure you primer/filler/clear paints are all compatible with the Holden Purple. (Its a crap colour imho, I'd go the Ford Phantom Metallic Purple)
PostPosted: Tue Nov 23, 2004 2:33 pm
I reckon ANY colour looks good, as long as the car is straight and the paint has been put on well.
Just remember that dark colours show every little ding and scratch, so your bodywork must be neat as a pin!!!!! If you think the bodywork will not be dead straight, choose a light colour. :wink:
