It is currently Tue Aug 19, 2025 10:46 pm
 Post subject: bright park globes
PostPosted: Fri Apr 06, 2007 5:55 pm
I is a mookenik
juz wanted to know if anyone as had a problem with the there rear park and brake globes brighter then usual.. the driver side globe is always on brake light and a guy at work told me that its because the globes in backwards, so i tryed it and hes right it does go back to normal but i cant put the globe back in properly.. like it wont lock back to place.
has anyone else had this problem? and how did u fix it?
PostPosted: Fri Apr 06, 2007 5:57 pm
put the globe back in and just swap the wires at the back of the light around.
Cheers Pete
PostPosted: Fri Apr 06, 2007 5:59 pm
I is a mookenik
interesting i like i like ill try that right now
PostPosted: Fri Apr 06, 2007 6:02 pm
I is a mookenik
fix it!!!!! SWEET THANKS FOR THAT
