It is currently Tue Aug 19, 2025 10:46 pm
PostPosted: Fri Apr 06, 2007 4:16 am
hi people i have a layland mini that has been modd to fit a morris 1500 subframe but i dont have that sub frame just want to know would it be easy to change it back to standerd or try get a 1500 subframe a modd it to fit the mini motor some help would be great will try to get pis up soon thanks people
PostPosted: Fri Apr 06, 2007 8:37 am
Hi,
Saw that car on eBay. There's a thread about the car somewhere on Ausmini.
No idea how mcuh work it would be convert back to a Mini subframe, we need to see what was modded in the first place. Post up some close up pics.
An 1100/1300 A series engine might bolt into the 1500 subframe with the mounts from a Morris 1100/1100S/1300. But personally I'd go with the 1500 engine or something more radical. You should be able to presuade a 4AGE or $EFTE Toyota engine into a 1500 subframe, as they have heaps more room than a Mini one.
Either way you are going to have rego hassles and require an engineers certificate (mod plate), unless the car was already mod-plated for the subframe swap. :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Apr 06, 2007 9:49 am
a 1500 sub frame won't take an a series engine BUT a 1300 subframe (out of the auto cars) has the same mounting points as the 1500 subframe but mount arrangments for the a series.
1300 subframes aren't that easy to find though..........
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
 Post subject: pic
PostPosted: Fri Apr 06, 2007 6:02 pm
i will try and get some pic when i pick it up on monday or tuesday thanks for your help
