It is currently Wed Aug 20, 2025 9:53 am
 Post subject: Long Wheel Studs
PostPosted: Sun Apr 08, 2007 9:33 am
Wats the longest length wheel studs available for Mini? I know that having a wide track is hard on wheel bearings....but who cares. Ive already got spacered drums on the rear with long wheel studs but now that i have the Honda Brakes up front, it looks like the rears need to have the track widened a bit more... So was thinking about fitting an 8mm spacer. But the studs i have are not long enough.
PostPosted: Sun Apr 08, 2007 9:53 am
Mite of found it... Mini Mania lists S studs as 2 1/4in (5.715cm), but they have extra long studs at 2 3/8in (6.032cm)...
PostPosted: Sun Apr 08, 2007 12:43 pm
I've got 80's on the rear :)
PostPosted: Sun Apr 08, 2007 3:50 pm
WOW.... Where were they sourced from?
PostPosted: Sun Apr 08, 2007 3:59 pm
is that 80mm of thread, plus the rest :shock:
PostPosted: Sun Apr 08, 2007 4:10 pm
MiniSpares, UK sells ENJO-1040 wheel studs, 78mm long with 27mm thread.
i use them with the spacered drum and additional 25mm spaceres, BTW not more wheelbearing problems than before
Rover 214 atm ....
PostPosted: Sun Apr 08, 2007 9:36 pm
I have some of the 78mm studs on the rear of my car. (see pic)
The ones on the left are regular S type ones, and the ones on the right are the newies.
:D
PostPosted: Sun Apr 08, 2007 9:41 pm
Some of our imports come in with spacer drums on the rear
and then 30mm bolt on spacers on the end of that.
And the wheel bearings are noisy
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Apr 08, 2007 10:36 pm
If running longer studs, I'd bung S tapered roller bearings in there.
BTW stay away from those horrid hexagonal `screw on' extension studs and the spacers that suit them. They should ban them from import and sale, they are an accident waiting to happen. :x
PostPosted: Sun Apr 08, 2007 10:49 pm
Oh come on Doc...
just cause they never tighten up properly and break studs...
what could possibly go wrong?
