Long Wheel Studs
https://www.ausmini.com/forums/viewtopic.php?f=2&t=30167
Author:  Hanra [ Sun Apr 08, 2007 9:33 am ]
Post subject:  Long Wheel Studs
Wats the longest length wheel studs available for Mini? I know that having a wide track is hard on wheel bearings....but who cares. Ive already got spacered drums on the rear with long wheel studs but now that i have the Honda Brakes up front, it looks like the rears need to have the track widened a bit more... So was thinking about fitting an 8mm spacer. But the studs i have are not long enough.
Author:  Hanra [ Sun Apr 08, 2007 9:53 am ]
Mite of found it... Mini Mania lists S studs as 2 1/4in (5.715cm), but they have extra long studs at 2 3/8in (6.032cm)...
Author:  smac [ Sun Apr 08, 2007 12:43 pm ]
I've got 80's on the rear :)
Author:  Hanra [ Sun Apr 08, 2007 3:50 pm ]
WOW.... Where were they sourced from?
Author:  buztoy [ Sun Apr 08, 2007 3:59 pm ]
is that 80mm of thread, plus the rest :shock:
Author:  KLAS [ Sun Apr 08, 2007 4:10 pm ]
MiniSpares, UK sells ENJO-1040 wheel studs, 78mm long with 27mm thread.
i use them with the spacered drum and additional 25mm spaceres, BTW not more wheelbearing problems than before
Author:  Harley [ Sun Apr 08, 2007 9:36 pm ]
I have some of the 78mm studs on the rear of my car. (see pic)
The ones on the left are regular S type ones, and the ones on the right are the newies.
:D
Author:  brickworx [ Sun Apr 08, 2007 9:41 pm ]
Some of our imports come in with spacer drums on the rear
and then 30mm bolt on spacers on the end of that.
And the wheel bearings are noisy
Author:  drmini in aust [ Sun Apr 08, 2007 10:36 pm ]
If running longer studs, I'd bung S tapered roller bearings in there.
BTW stay away from those horrid hexagonal `screw on' extension studs and the spacers that suit them. They should ban them from import and sale, they are an accident waiting to happen. :x
Author:  brickworx [ Sun Apr 08, 2007 10:49 pm ]
Oh come on Doc...
just cause they never tighten up properly and break studs...
what could possibly go wrong?
