| ausmini https://www.ausmini.com/forums/ |
| Rebuilding calipers https://www.ausmini.com/forums/viewtopic.php?f=2&t=30208 |
| Author: | smac [ Mon Apr 09, 2007 2:33 pm ] |
| Post subject: | Rebuilding calipers |
Quick question on flashing up some 8.4" 2 pot calipers: the little metal rings that hold in the outer seal (dust seal?) are a little pitted and manky. Do these come with a seal kit by any chance? Also, related question - are the mini disk hub and drum hub ball joints the same part? (I know metro are different) Thanks |
| Author: | drmini in aust [ Mon Apr 09, 2007 2:36 pm ] |
| Post subject: | Re: Rebuilding calipers |
smac wrote: Quick question on flashing up some 8.4" 2 pot calipers: the little metal rings that hold in the outer seal (dust seal?) are a little pitted and manky. Do these come with a seal kit by any chance?
Also, related question - are the mini disk hub and drum hub ball joints the same part? (I know metro are different) Thanks On a Cooper S the metal retainer rings come in the kit so 8.4s should too. All Mini ball joints are the same. |
| Author: | smac [ Mon Apr 09, 2007 3:00 pm ] |
| Post subject: | |
Goodo, just wondering cause the pics on minispares' site doesn't seem to show them. Thanks |
| Author: | drmini in aust [ Mon Apr 09, 2007 3:13 pm ] |
| Post subject: | |
the MM site shows 6 rings, like in an S kit- 4 would be rubber and the other 2, metal. http://www.minimania.com/web/Item/M2601/InvDetail.cfm |
| Author: | Harley [ Mon Apr 09, 2007 4:16 pm ] |
| Post subject: | |
Although the kits come with new retainer rings, I wouldn't throw out the old ones. Make an efort to keep them in good nick when you remove them. If the newies get mangles when you reassemble, you'll b glad you have spares.I know.....I've done it before. |
| Author: | drmini in aust [ Mon Apr 09, 2007 4:31 pm ] |
| Post subject: | |
I made a special service tool to fit the rings. it's a short bit of 50mm polycarbonate bar with a recess machined in the end 8mm deep and same diameter as piston. I push the piston into the fluid seal leaving 8mm sitting out, fit the seal ring into the steel retainer, and slide it down the piston. Then I put the service tool against it, and hit it gently and square with a BFH. The tool pushes it in flush all around. I agree, do save the old rings if any good. |
| Page 1 of 1 | All times are UTC + 10 hours |
| Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
