inlet manifold mystery... https://www.ausmini.com/forums/viewtopic.php?f=2&t=30227 |
Author: | harvey69 [ Mon Apr 09, 2007 7:54 pm ] |
Post subject: | inlet manifold mystery... |
looking at buying this on ebay.... but what is that hole on the inlet manifold....???? cheers.. EDIT>> just found this on ebay too....(i know different carb... but just looking at manifold) and it has the hole plugged? ? |
Author: | Mokesta [ Mon Apr 09, 2007 7:55 pm ] |
Big one is for the brake booster vacuum connection. Little one for vac advance. |
Author: | willy [ Mon Apr 09, 2007 7:56 pm ] |
Gaf would love the bling on that ![]() |
Author: | harvey69 [ Mon Apr 09, 2007 7:57 pm ] |
i aint got a brake booster.... so how would i go blocking it off EDIT>> thanks heaps for the quick replys !!! ![]() |
Author: | EST-071 [ Mon Apr 09, 2007 7:57 pm ] |
It is for a vacuum fitting for the brake booster. Cheers Pete |
Author: | Mokesta [ Mon Apr 09, 2007 8:01 pm ] |
No probs blocking it off. The set-up is the same as on an MG Metro. Mokesta has it. You just block the big port. It is supposed to have a big banjo fitting. The second photo shows 1/2 of that fitting. If you use this set-up you really should use the black insulating spacer shown in the second pic. Stops the carb getting too hot and making hot starting a ning nong. And, there's supposed to be a plate in there too. It shields the float bowl from the exhaust and supports the throttle cable. [edit: the carb isnt the HIF44 that the MG metros had so I dunno if the heat shield and cable plate is really supposed to be there.] M |
Author: | harvey69 [ Mon Apr 09, 2007 8:03 pm ] |
i have a spacer to be fitted onto it if i end up winning it..... is it just a threaded bolt that i "plug" the hole with..... EDIT>> cheers moke! |
Author: | Joe [ Tue Apr 10, 2007 9:01 pm ] |
tap and a brass plug would have it plugged in about 5 mins... unless its already threaded, then just a brass plug... 2 mins ![]() |
Author: | KLAS [ Tue Apr 10, 2007 9:08 pm ] |
should have 5/8 UNF same as temp sensor |
