A question about sub-frame cracks https://www.ausmini.com/forums/viewtopic.php?f=2&t=30232 |
Author: | Sparky [ Mon Apr 09, 2007 9:44 pm ] |
Post subject: | A question about sub-frame cracks |
I have found cracks in the sub frame in the engine bay, on the 2 round sections low and close to the fire wall (not sure of the correct name for this part). Just wondering is this common in mini's. If so is it a simple case of welding it and re-enforcing the spot? or do i replace this sub frame? any help or info on this is greatly appreciated. |
Author: | drmini in aust [ Mon Apr 09, 2007 10:04 pm ] |
Cracking is not common unless car has been in a prang, so check it's not twisted.. Just clean any paint and crud off, then weld it with MIG. |
Author: | 9YaTaH [ Tue Apr 10, 2007 6:50 pm ] |
Post subject: | Cracks |
Doc.....would it be prudent to take the engine out (relieve the stress) and make sure the subframe was straight by comparing to a known good one....then hitting it with a welder ![]() |
Author: | drmini in aust [ Tue Apr 10, 2007 7:06 pm ] |
Yeah I agree with Mick, don't try and weld it in there.. and check it for squareness with a tape measure and by sighting off, when you have it out. |
Author: | minimetoy [ Tue Apr 10, 2007 8:24 pm ] |
and make sure you cap of your fuel line if welding in the engine bay. Dan |
Author: | Sparky [ Mon Apr 16, 2007 4:45 pm ] |
thanks for the reply guys. i am about to get to work stripping the car tomorrow arvo with a mate. will tackle the sub frame at a later stage... |
Author: | Mike_Byron [ Mon Apr 16, 2007 5:13 pm ] |
Before you strip everything out Check and see if you can safely weld the cracks with the subframe in the shell - obviously with the engine out though. The reason is that if the shell of the sub frame is bent or twisted and you drop the sub frame out, chances are that you will have a torrid time getting it back in. Either the shell or the sub-frame will spring slightly. I had that exactly with my mini and had to do quite some extensive relieving and pulling to get it back in. The car does track straight and doesn't wear tyres abnormally so I was lucky. Don't think that another straight sub- frame will instantly solve the problem because it probably will be even harder to fit. Stick the car on a wheel aligner somewhere before you pull it pieces. If the car tracks straight then pull the motor and weld the sub-frame in-situ. |
Author: | Sparky [ Mon Apr 16, 2007 5:52 pm ] |
might be the way to go i recon.... might yank the engine out and weld it up while its still in there.... |
