It is currently Fri Jul 18, 2025 10:12 pm
 Post subject: Break light
PostPosted: Tue Nov 23, 2004 1:25 pm
Hi guys,
My break light is not working this morning and get caught by a police. The light globe is fine and I just had a break switch replaced. Can anyone tell me what the problem shout it be from?
Many thanks
PostPosted: Tue Nov 23, 2004 1:32 pm
maybe it's braken.
:twisted:
PostPosted: Tue Nov 23, 2004 1:34 pm
maybe try and swap the brake globe upside down so that it is facing the other way.. my m8 had the same problem and we just did that and it worked.. good luck
i like chicken
PostPosted: Tue Nov 23, 2004 1:52 pm
check to see if your getting 12v to the globe when you push the brake pedal. Do you have a pedal switch or a hydrolic switch?? check that the wires are still on the switch when you changed it.
1974 Moke - 998cc
PostPosted: Tue Nov 23, 2004 2:07 pm
maybe a fuse has gone **pop**
PostPosted: Tue Nov 23, 2004 3:28 pm
Check ya getting power with a multimeter, as Brad said. It could be wiring. More than likely the termination on either end has gone sour rather than the wire itself., so check them.
 Post subject: re lights
PostPosted: Tue Nov 23, 2004 4:01 pm
Most common problem , other than fuse, is that the terminals need cleaning. Take the globes out and run over there connecting points with some light sandpaper, see if that does the trick!
Steve.
