It is currently Mon Jul 21, 2025 8:02 pm
 Post subject: Clubbie Gauges
PostPosted: Mon Apr 16, 2007 11:29 am
I'm a bit of a novice when it comes to "the dark side" :lol:
But the Clubbies are starting to grow on me! :oops:
Saw one at the weekend with a three dial dash, speedo went to 200Kph and tach was 6000 redline?
What would that dash set up be from? :?
Also, when did the Hydro on Clubbies stop? 71 to 73? 8)
Sir Alec! we are not worthy!
PostPosted: Mon Apr 16, 2007 12:03 pm
Here's a pic.......
Anyone?
:shock:
PostPosted: Mon Apr 16, 2007 12:53 pm
Graham,
The dash's from a Clubman S have a 5500 redline and I think a 160kmh top speed. I think that dash is from an LS or a GT(not 100%). My '73 clubbie had hydro, not sure when they stopped.
Steve.
PostPosted: Mon Apr 16, 2007 1:01 pm
Thanks Steve, that's the reason for my question, I knew standard S's etc were 5500, but I thought GT's were 6500?
Mystery, maybe LS? Wheres Chris Czerial? :lol:
PostPosted: Mon Apr 16, 2007 2:53 pm
Thats a late pommie 1275GT dash right there.
Probably from an NZ spec car.
PostPosted: Mon Apr 16, 2007 3:08 pm
Hmm? maybe got converted to Kmh for NZ? Uk would have been MPH obviously.
200Kmh is 125 Mph!! :shock:
Velly interlesting!! :lol:
Thanks Anton............
PostPosted: Mon Apr 16, 2007 7:13 pm
A 1275LS dash goes up to 160kph and has a 5500rpm red-line. It also has two extra warning lights in the top corners of the surround.
PostPosted: Mon Apr 16, 2007 7:25 pm
yup 100% correct from everyone! 1275 GT dash ( i learned that from the GT professor)
PostPosted: Mon Apr 16, 2007 7:40 pm
beat me too it chris
cheers bob
1978 NUGGET GOLD 1275 LS
PostPosted: Tue Apr 17, 2007 9:50 am
whats the light ontop of the middle guage? directly above the smiths logo?
PostPosted: Tue Apr 17, 2007 10:06 am
You mean in between the fuel and the water ?? there is no light there actually - just an illusion in this case.
PostPosted: Tue Apr 17, 2007 1:21 pm
My 998 LS Clubman tacho goes to 8000rmp and the speedo to 160kph..
PostPosted: Tue Apr 17, 2007 2:30 pm
Yeah it's redlined at 5500rpm though, ay?
My 1275 LS guages are 160kph and the tacho has redline at 5500.
PostPosted: Tue Apr 17, 2007 4:38 pm
The Marina used the same gauges and went to 200kph (who knows why). When I changed diffs from a 3.44 to a 2.9 I swapped the 200kph Marina faceplate onto the existing Mini gauge which then gave nearly the correct speed. The Marinas had three gauge clusters, but mostly had a clock instead of a tacho. I can't remember what the redline on the Marina tacho was.
PostPosted: Tue Apr 17, 2007 4:41 pm
Sally has the same as Smokie, she redlines at 5500rpm :D
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
