Triangle Window Rubber
https://www.ausmini.com/forums/viewtopic.php?f=2&t=305
Page 1 of 2
Author:  68matic [ Mon Apr 12, 2004 10:28 pm ]
Post subject:  Triangle Window Rubber
how do you fit rubbers for the triangle window in the front of mini's?
i fit my drivers side because the pin at the bottom could be knocked out,
passenger side is still tight in both pins so i cant get to it
(are they called quarterlight windows?)
thanks
Author:  PhildoD [ Mon Apr 12, 2004 10:40 pm ]
Yup, that's the quarterglass. Do you want to change the rubber while its fitted to the door, or take the entire quarterglass frame out?
Author:  boost_morrre [ Tue Apr 13, 2004 1:10 am ]
im pretty sure u gotta take out that whole glass then there's a bolt underneath it that the window pivots on that u can take out to get the window out....otherwise i gues u could put a small slit in the rubber on the inside and wedge it in there if u can.
bit of a fiddle just for a seal but i guess its better than getting wet when it starts to pour.
Author:  68matic [ Tue Apr 13, 2004 1:53 am ]
i would like to change the rubber, easy/hard way, either way.
when i take the door trim off and stick my hand through a hole, i can feel a little bolt-like thing holding the bottom pin in, but cant get to it (space is like 2inches between there)
can you tell me your own ways of changing the rubber, cuttting it or not?
Author:  drmini in aust [ Tue Apr 13, 2004 7:17 am ]
I've not done one lately, but-
Should be able to drop the window, undo 2 screws at top, one inside- the quarter vent window is attached to the front window runner channel, it will all come out together, then you can see what you are doing... :wink: .
Author:  PhildoD [ Tue Apr 13, 2004 4:52 pm ]
I havent done one in bloody ages, but here goes.
Three screws hold the frame to the door. One on top and two on the forward edge. They hold the quarterglass frame in. The quarterglass frame is also attached to the forward runner track for the sliding glass.
With yer trim off, undo the two bolts to the forward runner track for the sliding glass. You should then be able to tilt the frame and runner track back away from the front edge of the door. You may need to peel some bailey channel out to get the room ya need. When dragging the whole thing out, bring it to the inside of the window frame.
When reinstalling the frame to the door, and adjusting it all, have the sliding window about half way up.
Author:  68matic [ Wed Apr 14, 2004 1:02 pm ]
thanks mates
i was gonna slit the rubber and do it dodgy style
Author:  min13k [ Wed Apr 14, 2004 4:06 pm ]
hey dooke if ya need a hand ya know me number i'll jum,p in tha yota and come round
makka
Author:  IwannaMini [ Wed Mar 09, 2005 7:17 pm ]
Are the instructions above same for all Mini's with quarter glass..?
:roll: its the next set of rubbers I have to change over.
Author:  68matic [ Wed Mar 09, 2005 7:57 pm ]
HAH
i still havent gotten round to do the passenger side after what, a year?
according to Anton 3 hours for the first side, 45 minutes for the other
ill let you take the first side Iwanna...
Author:  drmini in aust [ Wed Mar 09, 2005 8:14 pm ]
68matic wrote:
HAH
I'd buy Anton some BEER, then watch him do both.. :lol:
Author:  68matic [ Wed Mar 09, 2005 8:28 pm ]
thats an attractive option :lol:
i'd like to do it myself the proper way one day though
Author:  min13k [ Wed Mar 09, 2005 8:34 pm ]
dooke jack fixes everything when we are in our new place come over and we will do it
makka
Author:  EST-071 [ Wed Mar 09, 2005 8:34 pm ]
Have a look on JAM's web site, there is a step by step feature on this.
http://www.users.bigpond.net.au/brigidi ... seals.html
Author:  J_A_M [ Wed Mar 09, 2005 8:42 pm ]
:wink:
as mentioned.....the first one was a killer...the second was piss easy.... :lol:
Worth doing though!!! I can't stand windows and doors that don't seal...or have old crusty rubber.... :?
