Plugs - BOSCH WR9LCX? https://www.ausmini.com/forums/viewtopic.php?f=2&t=30555 |
Author: | GT [ Mon Apr 16, 2007 11:12 am ] |
Post subject: | Plugs - BOSCH WR9LCX? |
I was given 4 new Bosch WR9LCX plugs with me new GT. Is that the right code? That's all i see on them. I have never heard of them. Generally what would their application be? |
Author: | WasabiPimpNinja [ Mon Apr 16, 2007 11:45 am ] |
They're ford plugs. That's the code for the ones in the XF. I think they might be used in later model Falcons too... Dunno if they'd fit a Mini, but I'd doubt it ![]() |
Author: | cush [ Mon Apr 16, 2007 12:04 pm ] |
perhaps they're for a ford gt.. ![]() |
Author: | drmini in aust [ Mon Apr 16, 2007 12:55 pm ] |
I run Bosch W6DC in the 1360. No problems. I stopped buying NGK after I got two duds. ![]() |
Author: | GT [ Mon Apr 16, 2007 1:20 pm ] |
WasabiPimpNinja wrote: They're ford plugs. That's the code for the ones in the XF. I think they might be used in later model Falcons too... Dunno if they'd fit a Mini, but I'd doubt it
![]() Well I fitted them and took it for a fang. Doesn't miss a beat and has so much grunt! The code I mentioned was stamped into the metal part of the plug. On the ceramic part is R6 582 |
Author: | 64cooper [ Mon Apr 16, 2007 8:46 pm ] |
I was checking the suitability of different manufacturers plugs recently and going on the Bosch codes, the WR9LCX will certainly fit a Mini but whether it is long term suitable I wouldn't know. This is what the code interprets as. W = 14mm thread R = runs with a suppression resistor 9 = heat range (warm to hot) L = 19mm reach C = single copper anode X = factory preset gap of 0.44" |
Author: | GT [ Mon Apr 16, 2007 9:03 pm ] |
64cooper wrote: I was checking the suitability of different manufacturers plugs recently and going on the Bosch codes, the WR9LCX will certainly fit a Mini but whether it is long term suitable I wouldn't know. This is what the code interprets as.
W = 14mm thread R = runs with a suppression resistor 9 = heat range (warm to hot) L = 19mm reach C = single copper anode X = factory preset gap of 0.44" That's brilliant. Thank you. BTW...that remote diff housing you sold me worked very well. It's fitted and painted nicely now. |
