Clubbie Gauges https://www.ausmini.com/forums/viewtopic.php?f=2&t=30556 |
Page 1 of 2 |
Author: | graham in aus [ Mon Apr 16, 2007 11:29 am ] |
Post subject: | Clubbie Gauges |
I'm a bit of a novice when it comes to "the dark side" ![]() But the Clubbies are starting to grow on me! ![]() Saw one at the weekend with a three dial dash, speedo went to 200Kph and tach was 6000 redline? What would that dash set up be from? ![]() Also, when did the Hydro on Clubbies stop? 71 to 73? ![]() |
Author: | graham in aus [ Mon Apr 16, 2007 12:03 pm ] |
Here's a pic....... Anyone? ![]() ![]() |
Author: | Flying Brick [ Mon Apr 16, 2007 12:53 pm ] |
Graham, The dash's from a Clubman S have a 5500 redline and I think a 160kmh top speed. I think that dash is from an LS or a GT(not 100%). My '73 clubbie had hydro, not sure when they stopped. Steve. |
Author: | graham in aus [ Mon Apr 16, 2007 1:01 pm ] |
Thanks Steve, that's the reason for my question, I knew standard S's etc were 5500, but I thought GT's were 6500? Mystery, maybe LS? Wheres Chris Czerial? ![]() |
Author: | GT [ Mon Apr 16, 2007 2:53 pm ] |
Thats a late pommie 1275GT dash right there. Probably from an NZ spec car. |
Author: | graham in aus [ Mon Apr 16, 2007 3:08 pm ] |
Hmm? maybe got converted to Kmh for NZ? Uk would have been MPH obviously. 200Kmh is 125 Mph!! ![]() Velly interlesting!! ![]() Thanks Anton............ |
Author: | Morris 1100 [ Mon Apr 16, 2007 7:13 pm ] |
A 1275LS dash goes up to 160kph and has a 5500rpm red-line. It also has two extra warning lights in the top corners of the surround. |
Author: | czerial [ Mon Apr 16, 2007 7:25 pm ] |
yup 100% correct from everyone! 1275 GT dash ( i learned that from the GT professor) |
Author: | BOB1275 [ Mon Apr 16, 2007 7:40 pm ] |
beat me too it chris cheers bob |
Author: | cookie720 [ Tue Apr 17, 2007 9:50 am ] |
whats the light ontop of the middle guage? directly above the smiths logo? |
Author: | Mike_Byron [ Tue Apr 17, 2007 10:06 am ] |
You mean in between the fuel and the water ?? there is no light there actually - just an illusion in this case. |
Author: | Smokie [ Tue Apr 17, 2007 1:21 pm ] |
My 998 LS Clubman tacho goes to 8000rmp and the speedo to 160kph.. |
Author: | slinkey inc [ Tue Apr 17, 2007 2:30 pm ] |
Yeah it's redlined at 5500rpm though, ay? My 1275 LS guages are 160kph and the tacho has redline at 5500. |
Author: | paul_ewins [ Tue Apr 17, 2007 4:38 pm ] |
The Marina used the same gauges and went to 200kph (who knows why). When I changed diffs from a 3.44 to a 2.9 I swapped the 200kph Marina faceplate onto the existing Mini gauge which then gave nearly the correct speed. The Marinas had three gauge clusters, but mostly had a clock instead of a tacho. I can't remember what the redline on the Marina tacho was. |
Author: | Beefa [ Tue Apr 17, 2007 4:41 pm ] |
Sally has the same as Smokie, she redlines at 5500rpm ![]() |
