It is currently Wed Aug 20, 2025 2:48 pm
 Post subject: Plugs - BOSCH WR9LCX?
PostPosted: Mon Apr 16, 2007 11:12 am
I was given 4 new Bosch WR9LCX plugs with me new GT. Is that the right code? That's all i see on them.
I have never heard of them.
Generally what would their application be?
PostPosted: Mon Apr 16, 2007 11:45 am
They're ford plugs. That's the code for the ones in the XF. I think they might be used in later model Falcons too... Dunno if they'd fit a Mini, but I'd doubt it :)
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Mon Apr 16, 2007 12:04 pm
perhaps they're for a ford gt.. :)
PostPosted: Mon Apr 16, 2007 12:55 pm
I run Bosch W6DC in the 1360. No problems. I stopped buying NGK after I got two duds. :lol:
PostPosted: Mon Apr 16, 2007 1:20 pm
Well I fitted them and took it for a fang. Doesn't miss a beat and has so much grunt!
The code I mentioned was stamped into the metal part of the plug. On the ceramic part is R6 582
PostPosted: Mon Apr 16, 2007 8:46 pm
I was checking the suitability of different manufacturers plugs recently and going on the Bosch codes, the WR9LCX will certainly fit a Mini but whether it is long term suitable I wouldn't know. This is what the code interprets as.
W = 14mm thread
R = runs with a suppression resistor
9 = heat range (warm to hot)
L = 19mm reach
C = single copper anode
X = factory preset gap of 0.44"
PostPosted: Mon Apr 16, 2007 9:03 pm
W = 14mm thread
L = 19mm reach
That's brilliant. Thank you.
BTW...that remote diff housing you sold me worked very well. It's fitted and painted nicely now.
Users browsing this forum: No registered users and 165 guests
