It is currently Thu Aug 21, 2025 11:08 am
 Post subject: Fuel filters
PostPosted: Mon Apr 16, 2007 7:15 pm
Do you put a filter between the tank and electric pump, or between the pump and carb?
PostPosted: Mon Apr 16, 2007 7:23 pm
I have both sorts on mine now.
If the tank has rust inside, (mine did) bits of it can get to the pump, which won't help its performance.
If putting one before the pump I'd make it a biggie- to avoid starving the pump. I use an EA Ford filter.
If you use a Ryco under there keep an eye on it as they don't hold much crud.
There's no real need for one at the carb if you have one on the pump inlet line, but I still have a Purolator glass one up there too.
<edit> the Facet pump has no probs feeding the 1360's 45 Dellorto with both filters on.
Last edited by drmini in aust on Mon Apr 16, 2007 7:26 pm, edited 1 time in total.
PostPosted: Mon Apr 16, 2007 7:24 pm
mine is between pump (pump mounted on rear sub frame) and weber under the bonnet
Users browsing this forum: fuzzy-hair-man and 68 guests
