Kill switch - what's good? https://www.ausmini.com/forums/viewtopic.php?f=2&t=30592 |
Page 1 of 3 |
Author: | GT [ Mon Apr 16, 2007 10:04 pm ] |
Post subject: | Kill switch - what's good? |
What is the best form of Kill Switch? What have people used that worked well. Need to protect my GT ![]() |
Author: | Hanra [ Mon Apr 16, 2007 10:09 pm ] |
Ive got several hidden switches, 1 for fuel pump, 1 for 12V ign to coil and another for the 12v to the solenoid for the starter, once all of them have been closed u just push the start button and hope it still runs........ |
Author: | graham in aus [ Mon Apr 16, 2007 10:10 pm ] |
Anton, I like those battery disconnect things, best is, it's locked away in the boot! Also easily removed for shows / concours etc! ![]() ![]() |
Author: | graham in aus [ Mon Apr 16, 2007 10:14 pm ] |
http://cgi.ebay.ie/ws/eBayISAPI.dll?Vie ... osi_widget Good old E-Bay! But I got Mine from AutoPro ![]() |
Author: | pristic [ Mon Apr 16, 2007 10:21 pm ] |
Anton, is it an electric fuel pump or mechanical? In the past (on all my cars) I have used a switch to cut off the power from the 1. Fuel Pump, 2. Ignition and 3. Earth on the battery. It lets the car try to start, they can crank it over and over but it wont kick... and they think 'shitbox' and leave it alone. Peter. |
Author: | Gadgets mini [ Mon Apr 16, 2007 10:34 pm ] |
you can make all the gizmos you can but sadly if they want it they will come along with a crane and a flat top and shes gooooone ![]() a cut out will stop the joyriders hopefully |
Author: | pristic [ Mon Apr 16, 2007 10:43 pm ] |
Thats true, but most times its the joyriders that get em. A mate does alarms, I might get one of those pager/tracker type ones... But no police, if it gets stolen, its me and the boys going to 'collect' Damn I hate thieves... grrr ![]() |
Author: | pristic [ Mon Apr 16, 2007 10:44 pm ] |
Anton, Where are all the roundie fans? No one has said not to worry since its a Clubby... the mods have really frightened them off. Peter. |
Author: | poeee [ Mon Apr 16, 2007 10:48 pm ] |
pristic wrote: Anton,
Where are all the roundie fans? No one has said not to worry since its a Clubby... the mods have really frightened them off. Peter. Nar i'll stick up for his decision to fit anti theft devices. I mean, after all, it's got a Cooper S engine, a set of Cooper S discs and Cooper S right hand tank. ![]() ![]() ![]() |
Author: | drmini in aust [ Mon Apr 16, 2007 10:49 pm ] |
Pete, It's not just any Clubby, it's a Cooper S donor Clubby... ![]() ![]() 1/2 my car is ex- a bent Clubby GT. Yeah I really love em all....... even Clubbies. ![]() |
Author: | Monster Mini [ Mon Apr 16, 2007 11:51 pm ] |
drmini in aust wrote: Pete,
It's not just any Clubby, it's a Cooper S donor Clubby... ![]() ![]() 1/2 my car is ex- a bent Clubby GT. Yeah I really love em all....... even Clubbies. ![]() And Mokes ![]() ![]() |
Author: | Joe [ Tue Apr 17, 2007 12:32 am ] |
if its a mechanical fuel pump go see your local gas fitter for a petrol lock-off. just cut it into your line and put +12 to it. you can get brass olive fittings to cut into steel lines too.. if you were in vic I'd hook you up... also if its an electric fuel pump, you do have a safety switch don't you? if not you might like to go see your local gas fitter anyway. |
Author: | GT [ Tue Apr 17, 2007 8:36 am ] |
graham in aus wrote: Anton, I like those battery disconnect things, best is, it's locked away in the boot!
Also easily removed for shows / concours etc! ![]() ![]() Good point re: locking it in the boot! I was given one of those switches with the car (not fitted). Only prob is having to lift the boot board and battery cover EVERY time I leave the car and return to it! ![]() Fuel pump is electric (standard GT). A cut of switch on that is a good idea (for safety too). I would still rather a would-be thief has no ignition at all than have it crank and possibly start then stall. It might give a thief some hope. |
Author: | aaron [ Tue Apr 17, 2007 8:41 am ] |
My old van was fitted with a kill switch. It was the removable toggle type that you see fitted to rice boy cars. so you can take the toggle switch out of the car altogether, hence no charge at all without getting at the battery and rerouting it. Worked well. Location is imortant as anyone can start it if they have one of the toggle switches. I'll chat to you deirect as to where it is as it's best not to disclose on here for the new owners sake ![]() Cheers Aaron |
Author: | pristic [ Tue Apr 17, 2007 9:57 am ] |
Its all just wires and open circuits you want anyway... really. Some people have it so that the car must be in a certain state... or combination. EG, Must be in reverse and brake pressed to start it (otherwise its got no circuit) What I am saying is that people WILL look for a switch... a button or something similar. Many thieves know about the 'press the brake' switch... but a combo that only you know is better. Brake + Reverse + Left Blinker + High Beam or something ![]() Or, have a switch behind the rear pocket ash tray ![]() ![]() I mean, where can you really hide a 'swtich' in a mini ? |
Page 1 of 3 | All times are UTC + 10 hours |
