It is currently Sun Aug 03, 2025 5:22 pm
PostPosted: Fri Dec 06, 2013 9:17 pm
It's now 20 years since I last removed & replaced these. As Vizard recommends, removal to clean the oil galleries properly, is necessary.
Does anyone know where these can be obtained?
Any advice appreciated.
PostPosted: Fri Dec 06, 2013 9:22 pm
Berco supplied my screw in plugs - but it was a while ago...
Cheers, Ian
PostPosted: Fri Dec 06, 2013 9:26 pm
I used to buy brass welch plugs years ago, but lately all I have found available for Minis are steel ones.
Originals were steel and they lasted pretty well, so using brass was probably overkill. :wink:
[edit] I buy them from Karcraft.
edit 2
My bad I thought you meant the water jacket.. :oops:
re the oil ones I machine new brass ones, .504" dia and drive them in.
Last edited by drmini in aust on Sat Dec 07, 2013 11:15 am, edited 1 time in total.
PostPosted: Fri Dec 06, 2013 9:50 pm
I tap a thread and make bungs out of bolts to screw in. 9/16th UNF is the size i use i believe.
Just a bit of a job to have the bung screw in far enough but not too far and in some cases not protrude from the block.
PostPosted: Sat Dec 07, 2013 10:44 am
Many thanks for all the replies. :D
PostPosted: Sun Dec 08, 2013 1:31 pm
The Mini King
I have them in stock if that is any use to You 02 45776221
they are genuine parts but made a little different to what where before.
Regards
John
PostPosted: Sun Dec 08, 2013 9:36 pm
Excellent John, call call you 2morrow.
P.
