It is currently Fri Jul 18, 2025 9:09 pm
 Post subject: Crack in Extractors
PostPosted: Thu Apr 19, 2007 3:31 pm
Hi Guys,
I am now the proud owner of a set of LCB extractors with a large crack in the centre branch about 2 inches from the point where they bolt onto the head.
1. Can this be repaired or are they stuffed.
2. Is this a common Mini problem?
3. What is the most likely cause and what can I do to stop it happening again.
Thanks,
2008 Prado GXL
PostPosted: Thu Apr 19, 2007 3:36 pm
worn engine mounts will give you a wobbly engine that , if the exhaust mounts are good can bend the exhaust...
and the reverse is also true..
good engine mounts, bad exhaust mounts
PostPosted: Thu Apr 19, 2007 3:41 pm
Yeah it's repairable with a mig, but look at the cause like Cush said or you will be back at it in a few weeks.
PostPosted: Thu Apr 19, 2007 3:46 pm
it happened to me, so it's quite possible that it's a common thing.. ;)
PostPosted: Thu Apr 19, 2007 4:24 pm
SPI Rover's must have a flexi joint near the front otherwise it will keep happening
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Apr 19, 2007 6:00 pm
I had my extractors crack (not a flash pair, not sure of the brand, 3-1's) but it was caused by hitting a puddle after a long drive, the cold water on the hot extractors just cracked them like cold water on a hot plate. Took em to an exhaust shop, they said it wasn't worth rewelding because the metal had gone brittle and it would just crack again. I'm guessing that because yours are cracked up the top this wouldn't be the case, but something to keep in mind..
Peace
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Thu Apr 19, 2007 7:15 pm
Hmmm. I took out the flexi pipe when I fitted the extractors. Now I'm thinking not such a great idea.
Engine mounts appear to be OK.
Although my wife drove my car last week so maybe I could point the finger in that direction. :wink:
2008 Prado GXL
