In my digging into info re the lightening of flywheels I see that Vizard says that they weigh 28lbs/12.7Kg with 1300's being 32lb/14.5kg. (includes backplate) I presume he is refering to English made flywheels.
I have two flywheels I'm considering to use, one is a solid one the other a two piece and I presume Australian made. They both weigh 10.0Kg or 22lbs. Vizards says to aim for 18-19lbs/8.2-8.6kg
It appears on that limited observation that Australian flywheels are "halfway" lightened ie falling halfway between the English made flywheels and Vizards recommended for modifying original.
I intend to follow the Doc's advice and take 0.200" off the back of one of them(probably the solid one) and will let you know how much lighter it ends up.
David L
