It is currently Sat Aug 16, 2025 3:04 am
PostPosted: Fri Apr 20, 2007 9:06 am
I'll try again with this question. There must be someone out there who has had the same problem.
I have just about completed a resto on a 1970 MK 2 S but would very much like to install an original under bonnet insulation/sound deadener. I know there are after market ones but I want to try and make or buy the original thing which is either rockwool or fibre glass insulation stuff bonded together into a one piece shape that fits under the bonnet.
Any help would be appreciated.
PostPosted: Fri Apr 20, 2007 9:11 am
I have never had a Cooper S or a mini for that matter that had under bonnet sound proofing material as standard from the factory.
I vaguely remember seeing it as an after market product way back then.
All I ever saw was the fibre backed vinyl strip across the firewall.
Its just my experience though.
PostPosted: Fri Apr 20, 2007 9:24 am
Same here only ever seen it as after market stuff for early Minis. I've seen some of the kits about saying "like original" firewall material :?
PostPosted: Fri Apr 20, 2007 10:12 am
Try something like the MG's used - Its called PlastiFelt.
Try your local Motor Trimming supplier, i know Daley's have it. :wink:
Users browsing this forum: No registered users and 353 guests
