It is currently Fri Aug 15, 2025 11:02 pm
 Post subject: Door hinge numbers
PostPosted: Fri Apr 20, 2007 5:36 pm
Hi,
For the earlier (?) door hinges with the numbers 1-8, is someone able to tell me what numbers go where, in particular what numbers the upper drivers hinge should be?
Thanks in advance.
'78 LS 1275
PostPosted: Fri Apr 20, 2007 6:09 pm
I never knew they were numbered like that in early Mini's?
PostPosted: Fri Apr 20, 2007 6:58 pm
They were numbered funny, way back then.
It's easy to tell which is which though, I don't bother with the numbers-
the 2 with a very steep angle are the top ones, left and right are obvious.
The other 2 which have hardly any angle slope opposite to the top ones, ie the door slopes in at the bottom. So these are slightly thicker at their bottom edge.
:wink:
Users browsing this forum: No registered users and 337 guests
