Door hinge numbers https://www.ausmini.com/forums/viewtopic.php?f=2&t=30794 |
Author: | Andy [ Fri Apr 20, 2007 5:36 pm ] |
Post subject: | Door hinge numbers |
Hi, For the earlier (?) door hinges with the numbers 1-8, is someone able to tell me what numbers go where, in particular what numbers the upper drivers hinge should be? Thanks in advance. |
Author: | poeee [ Fri Apr 20, 2007 6:09 pm ] |
I never knew they were numbered like that in early Mini's? |
Author: | drmini in aust [ Fri Apr 20, 2007 6:58 pm ] |
They were numbered funny, way back then. It's easy to tell which is which though, I don't bother with the numbers- the 2 with a very steep angle are the top ones, left and right are obvious. The other 2 which have hardly any angle slope opposite to the top ones, ie the door slopes in at the bottom. So these are slightly thicker at their bottom edge. ![]() |
