After a Rebuild Getting Oil Pressure
https://www.ausmini.com/forums/viewtopic.php?f=2&t=30852
Author:  gafmo [ Sat Apr 21, 2007 6:50 pm ]
Post subject:  After a Rebuild Getting Oil Pressure
Brian poped around today and asked about getting oil pressure up
if it takes 20 secs stop and prime the pump.
if no oil after 20 secs.
wind with plugs out
Loosen the cooler pipe off the block, sometimes they get air lock there.
Just some additional info for you mate :wink:
Author:  Hanra [ Sat Apr 21, 2007 6:54 pm ]
I packed my oil pump with vasoline.. Wound it over with the plugs out and got oil pressure pretty quick. Then had to run the cam in once it started.
Author:  gafmo [ Sat Apr 21, 2007 6:58 pm ]
Yep packing the Oil pump with Vassos is a good idea as it does not drain out on instalation :wink:
Author:  drmini in aust [ Sat Apr 21, 2007 7:05 pm ]
You can also use cam lube, it's pretty thick and won't drain off in a hurry.
Author:  gafmo [ Sat Apr 21, 2007 7:17 pm ]
Yer thats what I used and so did Brian
