1.75 su on 998
https://www.ausmini.com/forums/viewtopic.php?f=2&t=30999
Page 1 of 2
Author:  Gnome [ Mon Apr 23, 2007 6:16 pm ]
Post subject:  1.75 su on 998
Has anyone put a 1.75 su on a 998 before? I am currently porting an unleaded head i got to replace the stock head, and while I was at it, I got a 1.75 with a water heated manifold to chuck on as well. I know I will probably run into problems with the jetting. Apparently the carb has been setup for a standard 1275, so I guess my real question is will this combination (worked head + 1.75) go well together or am I biting off more than I can chew?
Author:  Hanra [ Mon Apr 23, 2007 6:20 pm ]
Dont get caught up in the V8 scene, where they believe that bigger is always going to be better. Massive carbs, massive ports/valves, massive cams....
Id be inclined to go with a 1.5in SU.
Author:  lil-ute [ Mon Apr 23, 2007 6:32 pm ]
or a small weber
Author:  Hanra [ Mon Apr 23, 2007 6:33 pm ]
webber would be www.flatspotmaster.com.au
Author:  Mike_Byron [ Mon Apr 23, 2007 6:45 pm ]
Disregard the doomsayers and the weberists.
Yes the 1.75 in both HS6 and HIF44 form is a common carby on small bore motors. Graham Russell will tell you of a few well developed motors on his dyno, with a 1.75 carby, sucking all the air and fuel it can get.
It does have to be properly set up with t e right needle but its a good and common carby swap.
Author:  Smokie [ Mon Apr 23, 2007 6:47 pm ]
I have a 1.75 SU with a water heated manifold on my LS.. The motor was a 998 but has been bored out to 1030cc and worked over a bit but I found the 1.5 SU was just a bit to small to suit the new motor.
Author:  -=MiniMafia=- [ Mon Apr 23, 2007 6:50 pm ]
yeah, I have a HIF44 to go on my 998, just waiting on the head - let me know how u go!
thanks
Author:  Gnome [ Mon Apr 23, 2007 6:54 pm ]
OK then what needle should I go with and any other setup issues I should know about so that I can buy everything I need before I put it all on?
Author:  Hanra [ Mon Apr 23, 2007 6:56 pm ]
Hahaha....!!! How long is a piece of string?
Author:  TheMiniMan [ Mon Apr 23, 2007 6:59 pm ]
The first question that would need answering is "What Type of carb"???
That is to ask,,, is it a HS series or a HIF series
Float bown on the side???
or float bowl underneath????
Author:  Gnome [ Mon Apr 23, 2007 7:07 pm ]
float bowl is on the side, how do i tell if it is a HF or HIF?
Author:  Mike_Byron [ Mon Apr 23, 2007 7:18 pm ]
What is the carby off originally ?? please dont say an Austin 1800
Its a HS6 btw but that doesn't matter greatly.
Is the fuel bowl on an angle to the main carby body or is it straight and in line ????
Author:  TheMiniMan [ Mon Apr 23, 2007 8:08 pm ]
Buy an "OA6" mixture needle & shove that in & see what happens...
That should get you started & point you in the right direction mixture wise,,, the OA6 needle is a dam good "All-rounder" & will make just about anything with a 1.75HS carb on it work ok for starters.
But if you don`t quite know what you`re doing then just take it to some one who does,,, please???
& read what i just said again please,,,, the 0A6 needle is a good "STARTING POINT"
Not the be all & end all of mixture needles for your particular engine & state of tune/modification/package. Just a good starting point & wil;l run it ok till you have it tuned properly by some one who knows what they`re doing.
Treat it like a cheats way around tuning & because it will run pretty good straight up (as long as everything else is fine & dandy) you can tell everyone that you tuned it yourself & they will all think you`re a mini SU carb tuning GURU :-)
ok,,, maybe not a GURU :-)
But don`t tell anyone else , ok??? it can be our little secret :-)
Author:  Gnome [ Mon Apr 23, 2007 9:07 pm ]
yeah maybe I should get someone who knows what they are doing to have a good look at it after all I am just a noob. Oh well gotta start somewhere... Oh yeah the fuel bowl is on a slight angle too.
Author:  TK [ Tue Apr 24, 2007 7:28 pm ]
agreed with Matt OA6.
