depends if you count reverse! or if someone has installed a s/c gearset.
standard all gears are helical cut, except reverse on all gearboxes. remember 4th gear is simply the input shaft locked to the output shaft for 1:1 ratio.
drop gears are helical cut standard.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
