It is currently Mon Aug 18, 2025 7:55 am
PostPosted: Mon Apr 23, 2007 6:43 pm
I'll be draining my car sometime at somepoint. I want to know what it is so I can dispose of it properly and know what I'm up against when it leaks all over the driveway. :D
Thanks.
8)
PostPosted: Mon Apr 23, 2007 6:57 pm
It's basically water and alcohol with a bittering agent added.
I just hose it away, it's pretty harmless. Marginal as a concrete cleaner... :lol:
If you can't get the right fluid (I got mine from Karcraft) many people in US and elsewhere use a 50/50 mix of water and ethylene glycol (radiator coolant).
PostPosted: Mon Apr 23, 2007 7:01 pm
I just need to rid the rusty smelling water, not replace.
The mini is going dry.
:D
Thanks Doc.
PostPosted: Mon Apr 23, 2007 7:02 pm
Geez, if they locals up here knew that, there would be a lot of hydro mini's running around on there guts... Its probably gunna taste better then straight methylated spirits.
Could it be distilled?
:lol:
PostPosted: Mon Apr 23, 2007 7:04 pm
It is made from crushed martians, isn't that right Marvin? 8)
PostPosted: Mon Apr 23, 2007 7:05 pm
lol at hanra
it stinks to, and is all over my pops shed floor, and my clothes from stripping my cooper s
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Apr 23, 2007 7:54 pm
:D
Thanks Doc.
Good luck with conversion, hope it doesn't ride like our dry conversion with its 4 nice new Konis does ... (yes it was worse with old shocks on).
Our Clubby van is getting civilised suspension, it's called `hydrolastic' I think. 8)
PostPosted: Mon Apr 23, 2007 8:35 pm
Hey Doc, what a sensible idea for the van. Give me the hydro any time if you are to spend a lot of time driving a mini, however if you like the 'pedal to the metal' in your driving habits, stick to the dry suspension.
As for the composition of the hydro fluid, there was a thread on it early last year and the agreed mix was 50% pure glycol and 50% water.
PostPosted: Mon Apr 23, 2007 8:52 pm
Glycol?
Isn't that highly toxic?
Maybe I'll just fill an old oil contaner with it and work it out from there.
Now, How do I get it out of the car, and how much is there? Can I use an old
bike pump hose to direct it into a container? :?
PostPosted: Mon Apr 23, 2007 8:54 pm
I bet what's in it now is NOT glycol, if it's rusty it's the original water/alcohol stuff.
Glycol and water can be used, however.. :wink:
to get it out put a wide oil drain tank under the back, use the metal valve cap to push the valve stem in, GENTLY. Watch yer eyes, it's under 250psi+ pressure.
There's only a litre or so in each line.
PostPosted: Mon Apr 23, 2007 9:10 pm
what about getting it in?
Any sneaky home made ways ???
A1 :lol:
PostPosted: Mon Apr 23, 2007 9:19 pm
Grease gun. :D
PostPosted: Mon Apr 23, 2007 9:30 pm
Brake master cyl works a treat
& our woody wagon has been on hyro suspension for a million years,,, well ok, maybe not a million
PostPosted: Mon Apr 23, 2007 10:12 pm
I use ye olde Mini clutch one, mounted on an upturned Fiat pedal box.
It's worked for me for the last 20 odd years, with the odd set of seals and a few Mini brake hose replacements.
Better than a grease gun I reckon, you don't need to undo it to refill it. :wink:
Users browsing this forum: No registered users and 320 guests
