It is currently Wed Aug 13, 2025 2:30 pm
PostPosted: Wed Apr 25, 2007 5:47 pm
What do you do if your got electronic ignition and its missing a little bit down on the lower revs.
Morgs
PostPosted: Wed Apr 25, 2007 5:51 pm
I is a mookenik
missing? well if its missing down low can be a number of things
1. check that u have got cross fire in ur leads
2. make sure u have all the plugs working
3. make sure it has somehing to do with the ignition system lol
 Post subject: Hesitation?
PostPosted: Wed Apr 25, 2007 5:52 pm
Sure its "missing" rather than "hesitating" :?:
PostPosted: Wed Apr 25, 2007 5:59 pm
Same as usual, you need to eliminate the leads etcetera first before you can say it's the electronics.
But if it is, there may be very little you can do for it apart from replacement as they are mostly sealed units. It's very difficult to get them apart generally.
PostPosted: Wed Apr 25, 2007 6:17 pm
Check spark plug gap and condition and replace if needed.Do a resistance test on ht leads with a ohmmeter there should be 800ohms per foot of length of ht lead.make sure distributor cap is not
cracked or worn and rotor is not shorting on distributor sharft and ignition timing is set correct :D
PostPosted: Wed Apr 25, 2007 6:27 pm
and check its not constant, putt putt putt miss putt putt putt you know what comes next
Users browsing this forum: No registered users and 173 guests
