Any Mokes with YJBAB8R chassis prefix in Victoria!?! https://www.ausmini.com/forums/viewtopic.php?f=2&t=31133 |
Page 1 of 2 |
Author: | bnicho [ Thu Apr 26, 2007 12:02 pm ] |
Post subject: | Any Mokes with YJBAB8R chassis prefix in Victoria!?! |
Hi, I'm having fun trying to track down previous registration details on a Moke I have. It came to me minus engine, compliance plate and any papwerwork. All I have to go on is the Chassis number YJBAB8R4744. The Australian Associoation of Motoring clubs is trying to find the Moke in pre-1984 VicRoads records. What I need is the ORIGINAL engine number of a Moke with a close chassis number that was probably registered in Victoria prior to 1984. This will help them find a Moke close to mine and hopefully work through a few records to find mine! Anyone out there with a Vic Rego Moke with chassis prefix YJBAB8R4### that knows the original engine number of their car? Cheers, |
Author: | poeee [ Thu Apr 26, 2007 1:02 pm ] |
Any idea of age? Big or small wheel? Etc... I'd check mine, a 78, but it's at my parents place. ![]() |
Author: | graham in aus [ Thu Apr 26, 2007 1:27 pm ] |
Big Wheeler 1098 engine I do believe ![]() Would be 10YF/U/H***** ? ![]() I may have one at home, but I'm in NSW! ![]() |
Author: | bnicho [ Thu Apr 26, 2007 1:50 pm ] |
Yep, it's about 72/73, 13"wheels, 1098cc The prefix 10YF/U/H may be enough. But if I can get a complete engine number for one it will help heaps. Thanks, |
Author: | Morris 1100 [ Thu Apr 26, 2007 6:40 pm ] |
I have seen one with that prefix from 68/69. So that could explain the lack of ID/Compliance plate. ![]() |
Author: | graham in aus [ Thu Apr 26, 2007 7:07 pm ] |
B#gger! ![]() I have got YJB AB8R83## but the engine was not with it! If I can be of any more specific help, let me know ![]() Graham ![]() |
Author: | graham in aus [ Thu Apr 26, 2007 7:09 pm ] |
Oh forgot to say this one is 11/72 on plate ![]() |
Author: | bnicho [ Fri Apr 27, 2007 9:13 am ] |
The engine number prefix helps, but if I can get a full number that will help more. Thanks, |
Author: | Blokeinamoke [ Fri Apr 27, 2007 9:18 am ] |
YJBAB8R5097 99h834ajh43427 on the block at no 1 4/71 always thought it was an 1100 it appears its a 998 (?) based on the number |
Author: | bnicho [ Fri Apr 27, 2007 10:31 am ] |
Blokeinamoke wrote: YJBAB8R5097
99h834ajh43427 on the block at no 1 4/71 always thought it was an 1100 it appears its a 998 (?) based on the number That chassis number is pretty close BIAM, but the engine number is a 998 - much later than the car. It doesn't have the original engine number stamped anywhere on a build plate or something? |
Author: | Blokeinamoke [ Fri Apr 27, 2007 10:48 am ] |
nope not on the plate. I should check out what diff I have now |
Author: | graham in aus [ Fri Apr 27, 2007 10:49 am ] |
Actually Bnicho, the moke I quoted was supplied with a pile of bits including a later 998, I always thought the two didn't belong together? Who knows? The engine number prefix I quoted (10YF/U/H) came from both the Mini car club guide and Mini Kingdom catalogue. Both these sources have been wrong before! Have you tried the Moke Forum? ![]() |
Author: | bnicho [ Fri Apr 27, 2007 12:17 pm ] |
I've posted on the Moke forum, but it's down today. ![]() |
Author: | Blokeinamoke [ Fri Apr 27, 2007 1:00 pm ] |
bnicho wrote: Blokeinamoke wrote: YJBAB8R5097 99h834ajh43427 on the block at no 1 4/71 always thought it was an 1100 it appears its a 998 (?) based on the number That chassis number is pretty close BIAM, but the engine number is a 998 - much later than the car. It doesn't have the original engine number stamped anywhere on a build plate or something? The 998 in my Moke is pre-detox so it could be period but is most likely a mini unit installed when the original died (?) |
Author: | bnicho [ Fri Apr 27, 2007 1:18 pm ] |
Blokeinamoke wrote: The 998 in my Moke is pre-detox so it could be period but is most likely a mini unit installed when the original died (?)
Most probably, or even a later Moke/Mini one with an early head and no emissions gear. I wouldn't worry about it personally. ![]() |
